front axle disconnect
Old Dec 12, 2007 | 10:29 PM
d88fordny's Avatar
d88fordny
does anyone know if the d60 that came in fords(king pin version)the same or similar d60 that came in 94-02 dodges?
im wondering because i wanna put in a front axle disconnect from 4x4 posi-lok(http://www.4x4posi-lok.com/app_dodge.html)
the f250 i recently bought already had a f350 solid axle swaped into it and the front diff was welded(lincoln locker) and the axle disconnect would help with turning and while driving in 2wd
Old Dec 13, 2007 | 12:17 AM
Franklin2's Avatar
Franklin2
Those Dodge axles have central axle disconnect from the factory. Your Ford axles are one piece with lock-out hubs. Totally different system.
Old Dec 13, 2007 | 12:52 AM
d88fordny's Avatar
d88fordny
so if i just leave the hubs unlocked ill be fine driving with the welded diff?
Old Dec 13, 2007 | 02:21 AM
hoxiii's Avatar
hoxiii
yes.
Justin
Old Dec 13, 2007 | 02:47 PM
d88fordny's Avatar
d88fordny
hey thanks for the info guys
should i expect any problems with it?
Old Dec 13, 2007 | 09:40 PM
Franklin2's Avatar
Franklin2
I have heard a rumor that when you weld the diff, you have to do it a certain way or welding the gears weakens them. I think the preferred permanent way is to buy a spool.
Old Dec 14, 2007 | 12:26 AM
d88fordny's Avatar
d88fordny
i think theyre weakened because of the added stress put on all the parts.
i think ill just leave it in there until i would actually need to replace it.
