Trouble starting engine...
Old May 1, 2001 | 02:51 PM
wolf189's Avatar
wolf189
...been aware of this since i got the truck a few months ago but wasn't too concerned about it cause i had other issues to deal with first (and after all, it DOES start eventually...) but now the time has come and i once again am looking to you nice folks for some input.
When i first start the truck up in the morning (or any time it's been sitting for a few hours or more) the engine revs quickly, then drops back down to idle almost immediately, if i do not give it some gas by that time it will promptly die. Upon an immediate restart the engine fires up quickly and this time the revs stay high for several seconds before settling back down to a stable idle and it runs fine from there on out (put it in gear and drive away with no problems at all). However, if i give it some gas when i start it initially (and thus manage to keep it from dying) i then have to keep a fairly high amount of throttle applied (much higher than usual) when i put it in gear and let the clutch out or it will buck and stall within seconds.
Anyone had anything like this happen with their 4.9L? Any bright ideas? Any quick fixes which would be okay for a not overly mechanically inclined fellow to attempt?
as usual, thanks in advance.
wolf189
'93 F150 4x4 Regular Cab, Long Bed - 4.9L I6 w/5spd Manual
no mods... yet...
Old May 11, 2001 | 11:08 AM
whomrig's Avatar
whomrig
Old May 16, 2001 | 01:39 AM
hood's Avatar
hood
wolf189:
My son had the exact same problem with his 1989 5.0L grand marquis. It was the IAC (idle air controller). It was beyond cleaning. After the IAC was replaced the idle problem was totally gone. On a cold engine, the idle no longer surges, dips, and stalls.
Good luck, hope this helps you out...let us know what you find!
1981 F-150 2WD STYLESIDE P/U
4.9L 1 BBL CARB
C6 AUTO
2.73:1 LIMITED SLIP REAR AXLE
STABILIZER BARS FRONT & REAR
6100 LB GVWR PACKAGE
ORIGINAL OWNER
196,400 PLUS MILES
100% STOCK & UNREBUILT
BUILT FORD TOUGH!!!
Old May 16, 2001 | 01:43 PM
wolf189's Avatar
wolf189
The IAC you say? anyone know what one of those should cost me? and how hard it would be to replace? (every little thing that needs to be FIXED on this darn truck just puts the mods and upgrades i want to do that much further from reality... ugh)
wolf189
no mods... yet...
Old May 17, 2001 | 01:20 AM
hood's Avatar
hood
wolf189:
Call your local auto parts store for a price or if you happen to be very wealthy try your Ford dealer!
Once you physically have the part you should be able to replace it yourself. I would have done my son's but i didn't know that the problem was the IAC until i had it diagnosed at a shop. At least you have a pretty good idea of what it may be....no guarantees though.
4.9L 1 BBL CARB
C6 AUTO
ORIGINAL OWNER
196,700 PLUS MILES
BUILT FORD TOUGH!!!
9.ford.5
Offroad & 4x4
144
Jan 15, 2022 07:25 AM
DIY-ER
49
May 7, 2018 09:26 AM
92 Red F150
Dec 2, 2016 03:33 PM
motomofo
Nov 7, 2016 12:38 PM
dservansky
Sep 27, 2016 11:29 PM
