Sponsored by: Auxito
Front Wheel Bearing
Old Dec 12, 2007 | 06:48 PM
Henry H.'s Avatar
Henry H.
Front Wheel Bearing
How do I determine if I have ABS on front wheels of my 1997 F-150, 5.4, 4X4? I know I have them in the rear but not sure about the front. I've had the front tires to lock up but generally they do not. Thanks for any help!
Old Dec 12, 2007 | 08:22 PM
steve(ill)'s Avatar
steve(ill)
crawl under the truck or look over the tire. between the a-frames, the knuckle with the ball joint attached on each end- holds the hub /bearing. on the top of the hub bearing is the ABS speed pickup. you will see a black wire harness with two wires running into the hub area. there should be an attachment bolt on the knuckel, and wire leading out toward the top a frame bushing area.
Old Dec 12, 2007 | 11:12 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yup. You should see wires running along-side the rubber brake line down to the front hub. That's the way it was set-up on my dad's '04 Heritage.
