Hard to crank when up to temp
My '88 with 5.8L has become hard to crank when it gets up to temperature. It starts easily when cold, but sounds as if the timing is too hot when I try to start it after a routine drive. The timing is set at 10 deg with sprout connector off, but looks more like 15-20 deg with sprout connected at idle (800 rpm). ECT sensor looks good measuring the resistance, and comparing to temp/res chart. The starter is new, and so is the battery (850 CCA). HELP! Any comments are appreciated. Thanks,
The battery is new, 850 CCA. The cables are 2 years old, replaced when the total overhaul of the truck was done. I will check the connections on both ends to verify good contact. It has had some stalling issues in the past, for no obvious reason, so I like the TFI module option. Hard to crank, means that the motor turns over slow, kind of jerky; "runt...runt...runt" when up to operating temp, but spins over perfectly when cold. I don't really understand why the timing shifts at idle when the spout connector is reinstalled. procedure: engine off, remove spout connector, start engine, set timing at 10 deg. engine off, install spout connector, start engine, timing shows 20 deg, and jumping around. Thanks for all of the advise, so far.
Try holding the go pedal to the floor when starting while hot and see if it makes a
difference. You could use keyboard duster held upside down and blast the tfi with
the freon for 5 sec and see if it starts right up, If it is a heat soak problem the
duster will cool it down you could try it on other components too if that doesn't do
it. The computer is adjusting the timing for what it thinks it needs, Try starting it
while it is hot with the spout disconnected.
With the SPOUT plugged in, the ECU is controlling the timing, and it varies based on operating conditions. Sensors are quarried several times a second for changes, so the timing appears variable when observed. Do NOT put dielectric gel on your TFI. It is not the right grease for the job. Dielectric grease is intended to INHIBIT the transfer of energy. The grease on the TFI is a heat sink compound intended to facilitate heat transfer away from the module. These two compounds are opposites and you don't want to mix them up. Heat Sink Compound can be found at your local Radio Shack, and most other electronics supply stores. You'll spend about $2.00 and get an itty bitty tube that will last you about 20 years ( unless you go through 10 cars a year... ) Just apply a thin modest layer to the back of the TFI ( after cleaning it and the distributor of course )
Now....so far as the issue at hand....I would have the starter load tested. That being said...I've seen a lot of bad battery cable. Especially right where it bolts to the starter...it's exposed to the weather, road chemicals, not to mention the exhaust manifold heat...not a very friendly environment. You might look for signs of corrosion on the starter end....heat will multiply the problem.
Hope this helps !
-Scott Jones
Spokane, Wa
Hope this helps !
-Scott Jones
Spokane, Wa
'88 Should be EEC IV with the TFI on the Distributor. A popular mod on the Merkur List I'm on ( German Fords ) is relocating the TFI to the firewall, but there's nothing conclusive that says it will last any longer there, I never figured it was worth it. Sure, it's a $70 part, but it's lasted almost 20 years....not a bad return. It should definitely be heat sink grease. It aids heat transfer away from the module, just like in between the heat sink and CPU in your computer. Dielectric grease is for situations where you don't want a conductor ( plug boots for example ) Some guys use a tiny bit on the rotor in the distributor, tho I haven't personally seen anything that shows it has any use.
-Scott Jones
Spokane, Wa.
-Scott Jones
Spokane, Wa.
