Sponsored by: Real Truck
Powder Coating axles
Old Dec 12, 2007 | 12:55 PM
tlfw's Avatar
tlfw
<HR style="COLOR: #d1d1e1" SIZE=1> <!-- / icon and title --><!-- message -->
I see several examples of trucks that are lifted with the axles and other parts that appear to be powder coated. How specialized is this process, where can this be done and at what cost?
Old Dec 12, 2007 | 01:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have to take everything apart to get them into the cooker. Lots of money to have it done.
Old Dec 12, 2007 | 08:19 PM
high ho silver's Avatar
high ho silver
I have an alternative to the expensive approach. Dilute some simple green and spray everything down real good. Hose it off and make sure everything is real clean. When dry, get a few cans of ignition spray made by gunk. It is used to spray spark plug wires on older engines. Anyway this stuff makes everything look like new with a bright shiny coat. It is clear and makes the finished product look like new. P.S. I use this procedure under the hood also. Mine is a 2000 and looks better than most 2008 under the hood.
Old Dec 12, 2007 | 09:27 PM
MattyNJ's Avatar
MattyNJ
Great tip thanks! ya think that "orange" de greaser would work in place of the simple green?
Old Dec 12, 2007 | 09:31 PM
DCSpecial's Avatar
DCSpecial
Actually powdercoating isn't too expensive....as mentioned, you have to completely tear down the axle to get it done.
Me, I just clean them and use spray paint....
Old Dec 13, 2007 | 07:53 PM
high ho silver
I believe the orange stuff you are referring to leaves an oily film that will cause the spray to not adhere well.
Old Dec 18, 2007 | 01:03 PM
MattyNJ's Avatar
MattyNJ
If I were to spray paint the wheel wells leaf springs, drive shaft etc etc should I go with black semi gloss or flat?
Old Dec 18, 2007 | 01:07 PM
DCSpecial's Avatar
DCSpecial
Personal preference, I used gloss black on my frame:
The first time I painted I used gloss black on everything...looked nice but didn't really stand out at all, so I went with charcoal this time.
Old Dec 18, 2007 | 03:29 PM
RedDragon777's Avatar
RedDragon777
i am getting everything Line-X but that is only because i am getting a good deal on it (friend works for a local line-x dealer) but if i did not have that i would just simple green everything then hit it with some flat black rustolium or other heavy-duty spray paint
Old Dec 18, 2007 | 04:19 PM
MattyNJ's Avatar
MattyNJ
Thats what I was thinking...rustolium....maybe ill go with semi gloss....right in the middle!
Old Dec 18, 2007 | 04:25 PM
Vijay's Avatar
Vijay
That is what I did, used rust resistant paint from Autozone.
Old Dec 18, 2007 | 05:31 PM
5.4L to Freedom's Avatar
5.4L to Freedom
I prefer to use POR-15 for all my frame and axle coating. As far as I'm concerned, this there is the greatest stuff ever made. All you need to do is brush off the rust scales, and brush this stuff on. It'll even dry under water!
If you will be painting anything that gets hot like headers, use POR-20. The only thing is this stuff aint cheap, but a little bit goes a long way!
crazed87bronco
21
Feb 11, 2011 08:29 AM
CaptGuz
North Carolina Chapter
16
Jun 5, 2007 01:13 PM
1ole4d
Aug 5, 2006 02:54 PM
jeseitz
Nov 10, 2005 08:47 AM
