I need help!
I was trying to install aftermarket power windows, and in doing so I did not realize that I had "spliced" into the Resistor wire that runs from my ignition switch to my control module.
I ended up ruining the insulation from the ignition terminal to where I had the splice (about 1.5" in length).
I did not realize till after I made the mistake that this particular wire (red/green) was labeled " DO NOT CUT OR SPLICE".
What is the best way to remedy the situation? I can not seem to find anywhere that carries this type of wire and i sure don't want to re-wire the entire truck!
I hope someone out there has run accross this and can help.
Thank you in advance.
So by splicing a fusible link wire (the resistor wire is 16 GA.) Would this fix the problem?
The resistor wire seems to be made out of stainless steel rather than copper.
Thanks.
If truck is equipped with and Automatic Transmission, then there will be additional wiring thru the NSS then to the starter relay ( aka Starter Solenoid).
On a side note, I have found, most of the time, those resistor wires from the ignition switch under them dash boards run a little warm, when the engine is running. Someone chime in if I'm wrong.
I may be off the wall here but I thought that the resistance of the wire was related to it's length. In other words splicing in a replacment piece would effectively change it's resistance, albiet not by much, but I'd be inclined to just go to the junkyard and pull a new one in it's entirety.
Thank you all so much for your responses.
The first option I intend to try is to splice a piece of the correct resistor wire (about 3"). I will then test the wire and see how many ohms it is drawing. Correct me if I'm wrong,my understanding is that this particular wire should be within 1.05-1.15 ohms. Should I be alright if I can stay within the recomended ohms?
