THIS DARN CLUNKING!! -and I think I need shox..
Old Dec 12, 2007 | 11:11 AM
Bayer-Z28's Avatar
Bayer-Z28
Thumbs down THIS DARN CLUNKING!! -and I think I need shox..
ok. this is getting anoying! I have a clunking issue w/ the truck.. I can feel it in the floor boards.. It's a 2x4, and it does have king pins in the front end.. I REALLLLLY don't feel like doing them! What is the component called that connects the I beam to the frame via a bushing? -For the twin I Beam FT SUSP.. It almost resembles a torsion bar, but I know it's not.. Bushing time?
Another thing... I think I need shocks.. I can do the jounch/rebound test and it's fine, but whenever I come off a very bumpy section of road, the truck's ft end continues to bounce for a couple more seconds.. Is that just a bad side effect of the Twin I beam FT SUSP, or is it time for new shox??
Old Dec 12, 2007 | 12:53 PM
dixokai's Avatar
dixokai
I think the component your talking about is the radius arm.
Your shocks may pass the test when they are cold but when you work them hard (i.e bumpy road) they will heat up and not work so well. So my guess is yes you need shocks.
Old Dec 12, 2007 | 01:49 PM
alxsnmr's Avatar
alxsnmr
The radius arm bushings on the frame end can cause the popping noise as well when they become very worn.
Old Dec 12, 2007 | 02:56 PM
BigBluef250's Avatar
BigBluef250
Make sure the nuts are tight on the radius arms, Mine came loose and was making the same noise and feeling in the floor board. If they are loose buy new nuts there self locking teflon nuts.
Old Dec 12, 2007 | 06:39 PM
Bayer-Z28's Avatar
Bayer-Z28
^ Hmm.. I'll have to check that stuff out.. It almost feels like loose lugs..
Old Dec 12, 2007 | 07:14 PM
44dwarf's Avatar
44dwarf
That CLUNK might be a wasted shock bushing.
44
Old Dec 13, 2007 | 07:29 PM
shtse's Avatar
shtse
If the truck bounces excessively, get new shocks. Nothing worse than the tires not touching the road when you want them to.
Old Dec 13, 2007 | 08:56 PM
brown 4x4's Avatar
brown 4x4
I agree. Try shocks first. My truck seems to wear the bushings out long before the shock itself wears out.
44
Old Dec 16, 2007 | 12:27 AM
White Max's Avatar
White Max
I agree with replacing the shocks first. I had an annoying clunk on my 95 that turned out to be wasted/missing lower shock bushings. I replaced the shocks, and no more clunk, along with a much better ride.
-Rod
