Sponsored by: Real Truck
Nut size
Old Dec 12, 2007 | 08:15 AM
1pfieffer1's Avatar
1pfieffer1
Nut size
I just had new stainless studs put in for the exhaust manifold and guess what? The exhaust manifolds are warped !!! surprise !!!
I am leaning towards switching over to headers for my 5.4 f-250.
My questions are......
Does anyone know if I can use the stainless studs with headers or do I need to use bolts?
Does anyone know what the ford part number or the size of the nuts and bolts are for where the exhaust manifolds attach to the Y pipe?
Thanks
Old Dec 12, 2007 | 08:22 PM
ReAX's Avatar
ReAX
Stainless is pretty soft, I think I'd rather use grade 5 bolts probably cad plated if I had to go cheap. Not going cheap, I'd invest in ARP bolts. Studs are a pain, they can be difficult to remove and occasionally to set all the way. However, it makes little difference when it comes to headers vs cast manifolds.
I want to say they are 13mm bolt heads, probably 10mm bolts and I'd venture a guess of m10x1.5.
Old Dec 13, 2007 | 07:24 AM
1pfieffer1's Avatar
1pfieffer1
What is an ARP bolt? sorry for being ignorant but I don't recognize that term.
The studs that I replaced were only 8mm !!! just tiny little things, no wonder they break.......!!!
not worried about price, just don't want to go through all the work to have to do it again later, right now the manifolds are warped and I still have an exhaust leak to contend with, not as bad as with 8 studs broken, but still an exhaust leak........
Old Dec 13, 2007 | 08:11 AM
gcg82's Avatar
gcg82
ARP is a brand. Seem to be accepted as about the best quality bolts and fasteners.
http://www.arp-bolts.com/
Old Dec 13, 2007 | 08:14 AM
1pfieffer1's Avatar
1pfieffer1
Thanks......
SuperDutyScaler
Apr 27, 2012 11:39 AM
Chaosracing
Modular V10 (6.8l)
Mar 5, 2011 08:57 AM
96f150
Modular V8 (4.6L, 5.4L)
Sep 15, 2009 07:27 PM
wildboar12
1978 - 1996 Big Bronco
Nov 7, 2005 02:25 PM
