HOLY SMOKES BATMAN!
I also installed an Auburn Pro-Series limited slip rear diff while I was at it. I was just going to go with a No-Slip, but I figured the Auburn unit would be a little more forgiving on the street and still offer great off-road performance. One note on the diff. though; if you're running gears higher than 4.11 you will need a special pin that is notched to clear the ring gear (Jeg's wasn't nice enought to tell me this!). I ended up having to (ever so slightly) grind the inner edge of one of the teeth on the gear to get the pin out. It's nowhere near my mesh pattern, so I should be ok (I HOPE!).
TrailDawg
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
6" Lift w/35's
And STILL waiting to get my 4.30 gears installed!!!!
http://www.geocities.com/ProjectTrailDawg
TrailDawg
1993 F150 2WD
6" Lift w/35's
TrailDawg
1993 F150 2WD
6" Lift w/35's
Auburn Pro-Series Diff. w/4.30 gears
Could you please take the time to explain the ratios to me? I'm mechanically inclined, just know next to nothing about transmissions. My Mazda manual trans SUCKS, to say the least, and the syncro's are going (per my dad's advice).
You put 3.08's in? What does this mean?
Thanks!
-Nick.
Everyone else includes their truck in their .sig file so here is mine:
1996 F-150 XLT Pacific Green Metallic
Mods: Perm mounted CB with Dual Cobra antennas, 3" body lift, 31" tires, and a bunch of other smaller stuff.
1989 F-150 : 5.0, shorty headers, Flowmaster cat-back, K&N filtercharger intake, March pulleys, MSD-6T, soon to be Mass-Air...doesn't know she's not a Mustang
The 4.30 refers to the rear end gears. My stock gears were the 3.08:1 ratio, which means the pinion/driveshaft turns 3.08 times for every full turn of the ring gear/axles. The lower (numerically higher) gear rations provide better acceleration, but will take away from top speed, and vise-versa for higher (numerically lower) ratios.
When making a noticable change in tire size, it is highly recommended to change the rear end gears accordingly to retain acceleration and performance. I went from 29" tires to 35's, and with the 3.08's still in I lost use of my OD. With the 4.30's in now, I have my OD back and my cruising RPM is very close to what I was originally at originally. The easiest way I've found to calculate what gears are needed for you'r larger tires is this simple formula:
(New Tire Diameter/Old Tire Diameter) * Stock Gear Ratio = New Gear Ratio
Example:
(35/29) * 3.08 = 3.717 (3.73 is closest offered)
I wanted a bit more bottom end power and acceleration, so I plugged in a ratio of 3.55 for my stock ratio (which was the optional ratio offered by Ford).
(35/29) * 3.55 = 4.285 (4.30 is closest offered)
Ok, TrailDawg's "Gearing 101" class is now dismissed. :P
TrailDawg
1993 F150 2WD
6" Lift w/35's
As for gearing for 33's, I'd go with either 3.55's (equivelant to 3.08's stock)or 3.90-4.10's (equivelant to 3.55's stock). I know there's alot of guys on here running the 4.10's with 33's, and they seem to really like the combination.
TrailDawg
1993 F150 2WD
6" Lift w/35's
With 4.10's you will run higher RPM's but my gas mileage has not diminished all that much. I still get 15-16 mpg on the highway and about 14-15 in the city. Off-road the baby will crawl, crawl, crawl..
WHaynes
93 F150 4.9L 4x4
4" ProComp StII Lift
BFG 33in 4.10's
Detroit TrueTrac's
I noticed an MPG decrease, I can assure you!
Fun playing stoplight Grand Prix, tho...
Say, would those of you with 33s and a lift (specify) get a cab height measurement for me?
I'd like to go 33s next tire change time, but I park in a parking garage, and those joists are awful close...
Eddie
I'm not sure about mines height, but I do know it just BARELY fits into the garage now. I have about 3/4" clearance on what I think is a 7' door. It scares me every time I pull in, but it fits. LOL
TrailDawg
1993 F150 2WD
6" Pro-Comp Stage II Lift w/35's
did you order the gear set from jeg's too or from someplace local? i have a '79 f-250 with 3.73 gears (best as i can tell from the rolling tire in driveway method since the codes are obliviated from the door frame). i raised it a little and put 35"s on and now i have a rough just getting up to highway speeds let alone passing. time to upgrade the gears but am looking for the cheapest way possible. also, do you mind letting me know about the price involved of you had them installed from a pro or did you do them yourself? thanks man
'79 F-250 4X4 300/T18 with 35" grabber mt's
As for install price, one ow my wheeling buddies is a mechanic so I got off pretty cheap at $60. I know when I first called around though that I got quotes ranging from $125 to $400. Mechanics don't like doing them, so they usually hike the prices way up to scare ya off, or make doing it worth their time.
TrailDawg
1993 F150 2WD
