starter teeth
Old May 28, 2001 | 05:02 PM
figaro56's Avatar
figaro56
starter teeth
I have a 1984 F150 with a 300 six auto. Starter teeth sound like they don't mesh correctly (noisy when cranking). What are the correct number of teeth on the starter and flywheel? Actually binds when hot to the point of not turning over. Starter was replaced along with battery, solenoid and cables. Timing checks OK. Not running hot.
Old May 28, 2001 | 11:48 PM
PAUL_2's Avatar
PAUL_2
starter teeth
What brand of starter are you using ? My experience has been that finding an aftermarket starter that lasts , functions as it should is pretty much a waste of time & money . I dont think it requires any shims ? Did the original have any shims ?
Old May 29, 2001 | 07:33 PM
figaro56's Avatar
figaro56
starter teeth
Cardone starter from local parts plus. I am beginning to agree with you. Seems like the bone yard starters are better than this one.
Old May 29, 2001 | 07:34 PM
figaro56's Avatar
figaro56
starter teeth
no shims
Old May 29, 2001 | 09:40 PM
MSTRAWN's Avatar
MSTRAWN
starter teeth
Are you running headers on your truck? I had to install a heat sheild on the starter after the headers were installed. Seems the heat from the headers was too much for the starter. Just my situation. Mike.
1977 F-100
300 I-6 / C-4 (soon to be AOD)
Offy C intake w/Edelbrock 500CFM
Hooker Ceramic coated headers w/duals, turbos, tips, and 02's
MSD6A w/Blaster Coil
Headlight relay system (Delanty style)
Overhead Mount FM-CD etc.
R-134 A/C system (I'm cool)
Old May 30, 2001 | 08:13 PM
figaro56's Avatar
figaro56
starter teeth
No headers, but did put a shield on exhaust pipe just in case. Did it today, so I disabled ignition to check for a difference. Still bound up. If it gets past the first crank, it will crank and start
Old Jun 1, 2001 | 03:24 PM
traildawg's Avatar
traildawg
starter teeth
2pazr
Feb 17, 2009 05:20 PM
heybrent
1978 - 1996 Big Bronco
Sep 25, 2001 10:56 AM
hillbillyk
Sep 21, 2001 04:46 PM
heybrent
Sep 6, 2001 07:55 PM
figaro56
Electrical Systems/Wiring
May 30, 2001 06:28 AM
