Oil filter
Old Dec 11, 2007 | 08:34 PM
wreedZ71's Avatar
wreedZ71
Oil filter
Where is the oil filter located, how hard is it to change, and what is the easiest way to get at it on my 5.4L?
Old Dec 11, 2007 | 08:59 PM
vader86's Avatar
vader86
it should bo on the front of the motor on the left side they are easy to get to
Old Dec 11, 2007 | 09:02 PM
wreedZ71's Avatar
wreedZ71
I just looked at it and is appers oil will still all over the front diff and skid plate. Will it not?
Old Dec 11, 2007 | 09:16 PM
vader86's Avatar
vader86
i have done a couple of them i work at a firestone but dont remember any skid plate but i think you might have to remove the skid plate
Old Dec 11, 2007 | 09:18 PM
wreedZ71's Avatar
wreedZ71
remove the skid plate!? that seems like quite a hassle to change the oil filter!
Old Dec 11, 2007 | 09:19 PM
MBBFord's Avatar
MBBFord
The best time to change the oil is after the truck has been sitting over night without starting it. IF you do it this way, there will be very little oil spilt.
But if it was started recently, then if you give it a few turns, it will give a steady stream straight down, might hit the diff a little, but it does not drain directly on to it. Then finish taking it off and pull it to front, and slip it out.
Not in the best place, but I have seen worst.
Old Dec 12, 2007 | 01:46 PM
VFR_Man's Avatar
VFR_Man
If you still have the filter from the factory, expect it to be on tighther than you'd ever imagine. If you search for something like "+remove +oil +filter", you'll see all the posts about it. I had luck with the end wrench that exactly matched the filter flats and a bunch of extensions to get in front of the bumper, but others have been able to do it with a strap wrench and some arm contortion.
Someone the other day mentioned putting a plastic bag over the filter while removing it so the oil goes in the bag instead of elsewhere.
Old Dec 12, 2007 | 06:31 PM
mattd17's Avatar
mattd17
[QUOTE=MBBFord]The best time to change the oil is after the truck has been sitting over night without starting it. IF you do it this way, there will be very little oil spilt.
i have never liked changing cold oil..... i always do it while warm so it flows better......
and for the filter, i like using a ziplock bag...
Old Dec 12, 2007 | 07:05 PM
tomdoggie's Avatar
tomdoggie
THE SKID PLATE HAS A LITTLE GROOVE FOR THE OIL TO RUN OFF.
BUT I ALWAYS PUT SOME RAGS UNDER THE FILTER AND TAKE IT OFF FAST.
Not to much spill
Old Dec 12, 2007 | 07:49 PM
baitmaster's Avatar
baitmaster
After installing a CAI, the filter was much easier to get to, and I have always changed warm oil. I have an idea on dealing with this messy oil filter deal (especially the horizontally mounted ones). Have a little experimenting to do.
Old Dec 13, 2007 | 07:42 AM
brn2fsh1's Avatar
brn2fsh1
My 05 has skid plates. On top of the skid plate is a platsic drip pan that runs from directly under the oil filter to the edge of the skid plate. During an oil filter change, this drip pan catches spilled oil from the filter and routes it to the edge of the skid plate where it then flows into my black waste oil tub. When I change oil, I simply line the plastic drip pan with tin foil and change the filter. Once done, I throw the tin foil away. No mess.
Scott
