ABS Blinking - No tail lights
Old Dec 17, 2007 | 10:14 AM
aj197816134's Avatar
aj197816134
Took us a while to find, I had to get the schematics out and found the would run that way. WHen that fuse blows I bet it wont shift out of park. Let me know PM me with more questions or post.
Old Dec 17, 2007 | 10:26 AM
aj197816134
In our case it was a saturday nite, unplugged the harness and it was melted together and still causing a short, would create smoke and couldnt safely drive, was SAFETY reason to cut it, I am sure any reputable ford garage would take that into consideration
Old Dec 17, 2007 | 10:32 AM
superduty4x4's Avatar
superduty4x4
In that case maybe so, but I wouldn't go cutting wires unless necessary.
Old Dec 20, 2007 | 08:28 PM
msgntsu's Avatar
msgntsu
Thx. for all the recent posts. I just got back into town and took a quick look. I'm assuming that you are talking about the conn. with 3 wires plugged into the side of the master cylinder. Is that correct?
Superduty,
Yes, I guess I didn't fully understand what subford meant. Anyways, I checked the conn. but it's not wet, or melted. I had a real hard time getting the conn. loose. The clip is underneath and in a tough spot. I finally gave up until I got more info. Based on the emails below, I should take the truck over to the Ford house regardless to get this conn. replaced; even if it doesn't fix my problem.
AJ, no, this doesn't effect me driving the truck. It will shift out of park fine.
Comments?
Old Dec 23, 2007 | 08:47 AM
msgntsu's Avatar
msgntsu
Comments??
Old Dec 23, 2007 | 09:11 AM
subford's Avatar
subford
No it should have two wires on the plug.
Old Dec 23, 2007 | 09:18 AM
subford's Avatar
subford
Oops a bobo.
Sorry I see now that your pressure switch is located down on the frame.
Old Dec 23, 2007 | 10:56 AM
msgntsu's Avatar
msgntsu
Correct. Mine doesn't look like the one in your picture. The only conn. I have on the master cylinder is the one on the side (3 wires). It's the same one in your pic. that's behind the blue sheet. Where is my pressure switch located? You say down on the frame. Is it easy to find? If it's down on the frame could it still be my problem?
Thx. again for all the help and quick response.
Old Dec 23, 2007 | 11:28 AM
subford's Avatar
subford
It is possable that it is a problem.
Deactivator switch is located on top of frame rail under brake master cylinder for your 1993 only F-Series truck.
Old Dec 23, 2007 | 01:00 PM
msgntsu's Avatar
msgntsu
Thx. I think I found it. It looks like the one in your pic., but down below as you indicated. I felt underneath, but it wasn't wet. Anyways, I will get it fixed by Ford this week. This will at least correct this defect even if it doesn't fix my problem.
Old Dec 23, 2007 | 06:23 PM
JLDickmon's Avatar
JLDickmon
OK. I did as you suggested. Unfortunately, my fuse blew with all of this disconnected. Just for clarification. Is the turn signal switch conn. a little bigger than the brake light switch. The one I disconnected was directly below the steering column. It had two conn. tabs (one on each side). It was kind of hard to disconnect. If this is the right one, then none of this worked. What should I try next?
BTW.. Sorry for all the questions, but it's the only way that I can learn. If you disconnect the brake light switch doesn't that by default rule out everything downstream of that circuit (i.e. brake lights, trailer lights, etc.). This is what I was trying to ask earlier, but I don't think I was clear.
Thanks again for all the help. Maybe I can get this truck up and running again very soon.
no, because the brake lights run through the turn signal switch.
I completely forgot about the brake pressure (cruise deactivator) switch recall... just unplug the connector andtape it up out of harm's way untill you can get it in and have the fix done.
Old Dec 27, 2007 | 10:47 AM
msgntsu's Avatar
msgntsu
It's fixed!! It was shorted at the pressure switch.
I really appreciate all the help!
Old Oct 17, 2008 | 01:25 PM
  #28
buster5's Avatar
buster5
I'm having the same problem... the connector/harness/pressure switch in front of the mc and brake fluid reservoir is melted and leaking fluid causing a short. I've disconnected and it's not blowing the fuse. Is this covered in the recall for a '96 F-150? It doesn't seem to show up in the documentation.
Thanks!!
Old Oct 17, 2008 | 08:20 PM
  #29
boomersooner9's Avatar
boomersooner9
I didnt mean to post anything...i cant figure out how to post a thread
