Truck Troubles
Old Dec 11, 2007 | 05:40 PM
Bargod's Avatar
Bargod
Truck Troubles
Recently, my truck developed a slight hesitation when it would shift, kinda like it wasn't sure that it wanted to be in that particular gear. Then today, is started to backfire once in a while. I checked the tranny fluid and it's full enough, but has bubbles in it, not completely foamy but bubbles none the less. Any suggestions?
Old Dec 11, 2007 | 09:07 PM
Flip4ford's Avatar
Flip4ford
Low blinker fluid? :-)
Backfire is normally some sort of timing issue. Either mechanical (like timing gear/belt slipped a tooth), or electrical - (cracked distributer cap, bad module...) I am sure there are allot more smarts on the subject then what I carry around in my noggin..
Old Dec 11, 2007 | 10:25 PM
Bargod's Avatar
Bargod
Thanks for the tips Chad
Old Dec 11, 2007 | 10:44 PM
jjlogue3's Avatar
jjlogue3
I would be willing to bet it is timing as well. Put a timing light to it and see what you come up with. Timing would also explain the hesitation by not igniting the fuel at the right time or even not igniting it at all. You coluld always start off with the easy plugs/wires/cap/rotor tune up and see it that takes care of your issue.
Old Dec 11, 2007 | 11:05 PM
Bargod's Avatar
Bargod
Plugs and wires are nowhere near easy on these trucks (97-03 F-150), just ask Duane (or Diane).
Old Dec 12, 2007 | 05:51 AM
jjlogue3's Avatar
jjlogue3
Trust me I know I have changed mine twice on my 5.4l. So I guess that rules out the cap and rotor huh?
Old Dec 12, 2007 | 07:35 AM
fordboy_52's Avatar
fordboy_52
i sure with i could figure out why my 5.4 is missing. i can feel it in the body panels when i lay my hand on it.
Matt
Old Dec 17, 2007 | 11:35 AM
Bargod's Avatar
Bargod
It looks like I'm gonna have to take in to the shop to find the problem, I just don't have the stuff here to diagnose the problem.
Old Dec 17, 2007 | 12:35 PM
jjlogue3's Avatar
jjlogue3
Let us know what you come up with.
Old Dec 17, 2007 | 07:49 PM
husker's Avatar
husker
I had a 95 cougar with the 4.6 mod motor and new plugs and wires fixed the problem for it. They seem to be sensitive to needing good plug wires. If you change plugs, don't forget the anti-seize. It was a pain to change plugs and wires, and I imagine the trucks with the 5.4 is worse.
