3 DTC's
Old Dec 11, 2007 | 02:06 PM
2 stroke man's Avatar
2 stroke man
3 DTC's
i got 3 dtc's today when read them. since last reading i changed cps, and cleaned my ebpv tube, which should take care of those two right? i cleared them totally out, and ran it for a few minutes, and read again, and no codes. here they are:
03-P0344:Camshaft pos. sens. Circ interm
02-P0236:Turbo boost sens. A cerc. perf. -NO IDEAS WHAT THIS IS
01-P0470:Exhaust back pres sens circ error.
i think 1&3 should be fixed. what about 2?
Old Dec 12, 2007 | 07:38 AM
2 stroke man
any ideas what the turbo code is?
Old Dec 12, 2007 | 08:28 AM
tjbeggs's Avatar
tjbeggs
Has to do with the MAP sensor. But if it doesn't come back I wouldn't worry about it.
Old Dec 12, 2007 | 08:34 AM
2 stroke man
i just got off the phone with a local ford dealer. they said that most of these trucks throw those codes. of course in the conversation the same guy told me that 99.5-up trucks dont have a wastegate. so idk if he knows much at all
Old Dec 12, 2007 | 08:42 AM
Cuda_jim's Avatar
Cuda_jim
Did you clear the codes with a code reader? Some can't/won't do it.
Remove #22 & #9 fuses under the hood to clear the codes..or remove the battery cables.
I agree with Tim, the MAP sensor is the cause of P0236.
Did you touch the MAP sensor or the line when you were fixing stuff?
Old Dec 12, 2007 | 09:20 AM
2 stroke man
where are they?
Old Dec 12, 2007 | 09:39 AM
ono_55's Avatar
ono_55
If you are asking about the fuses they are in the main juction box under the hood on the drivers side fender well. The map sencer is on the fire wall, next to heater motor, it well have a rubber hose going to it.
Old Dec 12, 2007 | 09:44 AM
2 stroke man
come again on the map sensor
Old Dec 12, 2007 | 09:48 AM
ono_55's Avatar
ono_55
The map sencer well be on the left side on the fire wall as you look at the motor it well have a hose going to it, look at the left side of the moter were the intake go to the heads you well see a hose on the left side follow it ti the map sencer.
Old Dec 12, 2007 | 09:54 AM
2 stroke man
is they a way to check it
Old Dec 12, 2007 | 09:58 AM
ono_55's Avatar
ono_55
When i thought me was going bad i just unpluged it, if the truck runs better it is bad, if it runs worse it is good. I know sounds funky but out in the sticks with out a code reader you do with what you can.
Old Dec 12, 2007 | 10:00 AM
ono_55's Avatar
ono_55
I would try what cudajim said, unplug those fuses and see it the codes came back.
Old Dec 12, 2007 | 10:04 AM
2 stroke man
love my grammer dont ya
Old Dec 12, 2007 | 10:05 AM
ono_55's Avatar
ono_55
mine ANTE no better.
Old Dec 12, 2007 | 10:06 AM
tjbeggs's Avatar
tjbeggs
yes as long as the rubber hose is hooked up to the MAP you can unplug the elctrical connector and if the truck runs better then the sensor is bad. if it runs the same or worse its fine
