Valve Cover Gasket DIY
Old Dec 20, 2007 | 12:00 AM
Rabbit16v's Avatar
Rabbit16v
Originally Posted by F150xlt
There's a rubber hose about 17" long 3/8 ID from the bottom of the plenum to the PCV valve that plugs into the top rear of the valve cover grommet.
Yup, that was it. When I took the intake off, I didn't notice that the hose came from there (never dawned on me either). Then when I put it back together, it managed to sit under the intake to where I couldn't see it. Problem fixed now!! Next up, why do I have brake fluid leaking and why don't I have heat/ac.
Old Dec 20, 2007 | 04:11 PM
flareside_thunder's Avatar
flareside_thunder
Where's the fluid leaking from?And the ac/heat could be a bad blower motor......
JR
Old Dec 20, 2007 | 07:25 PM
Rabbit16v's Avatar
Rabbit16v
JR
Honestly, it's leaked once and that was it and I've had it for a couple of months. So I haven't really looked.
As for the heater, it blows out of the defrost but not the vents. I'm waiting out the rain to check for vacuum leaks first.
Old Dec 20, 2007 | 08:00 PM
flareside_thunder
That's a good start.......check the brake reservoir.
JR
FrankeeD
Feb 7, 2021 09:31 AM
JessieDM
17
Feb 9, 2015 07:52 PM
timbersteel
May 12, 2011 06:29 PM
Danny_Ocean
Mar 20, 2006 10:54 AM
hiram6
Bronco II
Jul 2, 2003 03:26 PM
