GLOW PLUG's unknown potential...
Old Dec 11, 2007 | 02:59 PM
ron's power stroke's Avatar
ron's power stroke
Originally Posted by empiretc
I had already done this on my Dad's truck (1990) when I was fighting his glow-plug situation and had to install a manual push button for him. It was what I used as the ON indicator for him.
I am real curious about just how much the plugs are used on my truck compared to others. It's hot 99.9% if the time here where I live. I know when changing/testing the GPR, it would energize momentarily, but I wouldn't be surprised if that's all.
I am going to have to do this as I am in need of another project. AFFORDABLE one too, due to XMAS .
happy holidays!
my mistake..sorry about that..you did post about doing that..it is a good mod..i havent done it yet..but have all the parts to do it..i got to do my battery cables and change my oil too..i have every thing for them too..but christmas has slowed a lot of things down for me as well..
Old Dec 11, 2007 | 03:07 PM
Smokin''s Avatar
Smokin'
Smokin
Originally Posted by Kwikkordead
Hmmm, buzzing sounds more like a fuel pump running to me.
Are you sure that you are not hearing the pump instead?
positive. Can hear the pump sometimes too, different noise.
Relay is brand new, replaced the beginning of this year. The noise is an "electrical" noise is the best I can explain it.
I have touchy ears, though.
Old Dec 11, 2007 | 03:21 PM
empiretc's Avatar
empiretc
Absolutely nothing to apologize about, Ron. I had done it but never posted about it. PROPS to WMRiceman!
XMAS has slowed a lot of things down, except the amount of outgoing money...
Old Dec 11, 2007 | 04:57 PM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
Positive, cause I can hear when the pump shuts off, The GPR is on much longer. Now with the light, I kinda have personal proof which one I'm hearing.
Old Dec 11, 2007 | 10:39 PM
nhill2090's Avatar
nhill2090
dodges have glow sticks
Old Dec 11, 2007 | 10:40 PM
gtlegacy's Avatar
gtlegacy
ok so i hooked up my led today and nothing, no light. I tested the two small connectors and they have power. The main from the bat also had power. Does anyone know the purpose of these signals because they were hot when the truck was hot and cold. I have tried to find the schematics but have had no luck. My truck is a 2000 CA model, so i only have one gpr. I think with the two small wires hot it should be triggering but why are they not turning off? Also i went to pep boys and picked up a relay which didnt work either so im thinking ill just go to ford, or i have a different problem.
Old Dec 12, 2007 | 12:23 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Got a question guys how do you rig this light up to work I like this Idea
Nick
Old Dec 12, 2007 | 12:40 AM
gtlegacy's Avatar
gtlegacy
Think i found my problem. The purple small wire is a computer controlled ground which is the trigger for the relay. From other research online i found that many of the ts chips were not designed for the ca pcm. I removed the chip and will see if the relay will trip when cold in the morning. If it still doesnt fire, do i need to buy a gpr controller CA only or a pcm?
Old Dec 12, 2007 | 03:06 AM
ron's power stroke
Nick
link in post 4 will tell you how..
Old Dec 12, 2007 | 06:57 AM
TurtleRacing
PSD Addict
Nick
I ran the red wire on the LED to the post on the GPR that feeds the GP's, ran the black wire to the ground on the battery.
Old Dec 12, 2007 | 07:41 AM
Kwikkordead's Avatar
Kwikkordead
Gtlegacy your CA only truck is different than the rest of the fleet. We have two relays where your one is and you have a special controller for your glow plugs.
I cannot offer any advice on how to fix it, but it sounds like you are on the right track.
Old Dec 12, 2007 | 09:31 AM
weekendwarriorfsw32
Master of Strokes
Ok another question if I bought my truck in ca does that mean I have a ca only truck because I have a GPR for the glow plugs. I am I missing something,
Nick
Old Dec 12, 2007 | 06:24 PM
  #28
weekendwarriorfsw32
Master of Strokes
I take that back I went out to the truck and cant find the GPR. Where is it on ca trucks
Thanks
Nick
Old Dec 12, 2007 | 09:03 PM
  #29
lhud's Avatar
lhud
TurtleRacing says the voltage from the GPR to the glow plugs stays on even though the engine is at operating temp. So, does this voltage continue to operate the glow plugs or does the PCM somehow interrupt the voltage between the GPR and the glow plug when the engine is at operating temp.?
Thanks,
Old Dec 12, 2007 | 10:03 PM
  #30
nhill2090's Avatar
nhill2090
Thanks
Nick
thats because it dosent look like the standard GPR...its differnt and funky.. do a search, it works wonders
