carb tune-up
Old Dec 10, 2007 | 09:03 PM
Kuskoal's Avatar
Kuskoal
carb tune-up
hey its me again asking for s'more help .
1: what jets came with a stock/sea level holley 4160 #6919?
2: what jets should i be using at an elevation at about 4000-5000 ft higher than sea level?
3: how can you tell if a power valve is broken
4: i tuned my carbs idle screws with a dwell/rpm meter. is that right?
5: around hat range will my floats be set at?
6: how do i adjust the secondaries in general?
7: will a vacuum gauge help or would the rpm meter be suffice?
THANK YOU in advance my truck is almost ready for smog, just gotta tune that carb
Old Dec 11, 2007 | 10:20 PM
kermmydog's Avatar
kermmydog
Your carb came with 122-622 main jets, a blk secondary spring, power valve 125-206. A blown power valve causes excess gas. If your carb doesn't have blowout protection added then it could very well be blown.
The rule of thumb is one jet size down per 2000 ft. But you have to play with that in most cases. Adjusting secondaries is done with changing springs. Parts & kits are available from Jegs or Summit at a good price.
