Dodge guys wont like this very much
Originally Posted by rollerstud98
1.) Yes they both are
2.) Not neccessarily, with pulls like that once you start to spin your tires its over if you don't let off the throttle because when the tires spin, the other guy can just pull you around like nothing.
You need to do another search on your numbers, last I heard both are 350/650 with dodge having it detuned in the 4500 and up trucks, also dodge makes peak torque at 1400 rpm.
The 5.9 was 305/610, and the 6.7 is 350/650
According to wikipedia, the cummins makes 650 ft-lbs at 1600RPM, while the 6.4 PSD makes peak at 2000RPM
This is an old video of my pulling a 3500 Goat dually cummins with my lifted 03 350 V-10. I was in 2wd, so 2 wheels vs. 4 and I still pulled him.
Bad video, bad comentary, but what else do you expect when you're drunk in a dried out pond bed.
This is what happens when people give you alcohol and a camera....
Do not try this at home....
The stunts were performed by professionals....
As well as the consumption of alcohol....
This kind of thing also take a complete lack of inhibition and common sense....
http://myspacetv.com/index.cfm?fusea...ideoid=1078045
