I got lucky today. 140 mile trip home this morning trying to figure out why my '87 F-150 would vibrate my fillings out at 75 MPH. I finally reasoned it down to drivetrain and was suspecting rear U-joint when I heard a thump and clang behind me.
I figured I lost part of the exhaust system until I noticed a driveshaft spinning across the highway into the ditch. I calmly pulled over, locked the hubs and shifted into 4-wheel before backing up to retrieve the driveshaft.
I think the rear joint broke, then took the front one -- lucky since it left the slip-yoke in the transfer case.
Now I've got a front-wheel-drive pickup until I get it fixed/replaced.
There are a couple of areas busted out where the snap-rings fit so I probably shouldn't use it as is.
Dang, that sucks. That happend to a guy drivin a 90 F150 in front of me on the interstate a couple days of go. Hope you get her back together with no problems.
