Distributer shaft breaking!
Old Dec 10, 2007 | 01:48 PM
JCastellaw's Avatar
JCastellaw
I have broke two dist. shafts. Anyone know what causes this?? Its in a newly built 351w procomp cam and hei distributor!
Help!!!
Old Dec 10, 2007 | 02:31 PM
Conanski's Avatar
Conanski
Crappy quality shafts.. What oil pump and oil is in the motor?
Old Dec 10, 2007 | 02:54 PM
Kemicalburns's Avatar
Kemicalburns
are you running the proper dizzy gear in regards to the cam choice either flat tappet or roller. either use a different dizzy gear
Old Dec 10, 2007 | 03:10 PM
JCastellaw's Avatar
JCastellaw
351w 10w-40. motorcraft oil and a Melling Hi volume!
Old Dec 10, 2007 | 03:55 PM
Kemicalburns
why are you running a hi volume pump? that is probably whats causing the failure. you need to get a specific dizzy shaft.
Old Dec 10, 2007 | 10:04 PM
BEWOLD's Avatar
BEWOLD
High volume pump and stock shaft = breakage. All books and build ups ive read say the high volume pump is not usually necessary, but always upgrade to the higher quality shaft. Cheap insurance.
Old Dec 11, 2007 | 08:49 AM
JCastellaw's Avatar
JCastellaw
Cam is not stock. It's a 268 Comp Cam. So who all thinks it's the Oil pump???
JCastellaw's Avatar
JCastellaw
Also, what's a dizzy shaft. comp said a brass gear is not nessary
Old Dec 11, 2007 | 10:11 AM
Kemicalburns
is it a roller or flat tappet cam?
why are you running a hi volume pump. the only reason for such a need is a motor built with loose tolerances. most builds only need a regular pump.
Old Dec 11, 2007 | 10:13 AM
JCastellaw's Avatar
JCastellaw
Flat tappett
Old Dec 11, 2007 | 11:50 AM
Kemicalburns
ok, now why for the hi volume pump? contact the pump manufacturer and see what they recommend for a oil pump drive shaft
Old Dec 11, 2007 | 01:28 PM
JCastellaw's Avatar
JCastellaw
Engine builder thought I needed it! Why, I do not know
Old Dec 11, 2007 | 01:29 PM
JCastellaw's Avatar
JCastellaw
Any one else had this problem. What are your thoughts on the hi vol oil pump? Is that the problem????
Old Dec 11, 2007 | 02:33 PM
Kemicalburns
i would take it back to the builder and make them fix it.
Old Dec 11, 2007 | 02:44 PM
JCastellaw's Avatar
JCastellaw
Already tried that once. this is the second time. He is not touching it anymore!
