Distributer shaft breaking!
Old Dec 11, 2007 | 02:46 PM
JCastellaw's Avatar
JCastellaw
http://classicbroncos.com/forums/sho...859#post991859
Old Dec 11, 2007 | 04:57 PM
Kemicalburns's Avatar
Kemicalburns
the hi volume pumps are known for breaking a stock pump drive shaft. the mechanic that installed it should have installed the proper one. i would at least make him purchase the part.
Old Dec 11, 2007 | 06:55 PM
BEWOLD's Avatar
BEWOLD
Sorry, wasnt clear enough in my post. Like Kemical just said, cheap oil pump drive shaft + high volume pump = broken oil pump shaft. A high volume pump is not usually necessary especially if the engine isnt prepared properly, it can be bad, can push stock plugs out of oil gallerys, increased aeration and windage, broken pump shaft, not to mention if its of high enough volume it can nearly empty the pan and fill the lifter valley
Old Dec 13, 2007 | 05:58 AM
ken75ranger's Avatar
ken75ranger
Change the oil pump to a standard one. Put in a new oil pump shaft and the mallory distributor in that Bronco thread. That should take care of those issues. I regularly run my 5.0 with those parts up to 5000 rpms. No issues here.
rusbukt
Sep 2, 2012 08:14 PM
mjm1
Apr 9, 2011 07:57 PM
gpbullock
Jul 11, 2009 01:12 PM
JBronco
1978 - 1996 Big Bronco
Feb 4, 2002 10:09 AM
