Warning buzzer
Old Dec 10, 2007 | 12:50 PM
scrapyardking's Avatar
scrapyardking
Warning buzzer
Well my girlfriend wrecked her car and now has to drive my truck. and I was wondering how to install a warning buzzer for the engine temp. and the oil pressure because she has been known not to keep an eye on the gauges.
So how does one go about doing this?
Old Dec 10, 2007 | 01:39 PM
blue68f100's Avatar
blue68f100
The only way I know of is install the sending unit for the idiot light along with the gage unit. Will require some additional wiring to work.
Old Dec 10, 2007 | 02:57 PM
76supercab2's Avatar
76supercab2
Don't let her drive the truck.
[/problem]
Old Dec 10, 2007 | 03:03 PM
fmc400's Avatar
fmc400
MSEE
[/problem]
You beat me to it! Seriously though - if you have an oil pressure gauge, then you would need to tee off of the factory sending unit and install a dummy-light sending unit and wire a buzzer to ground itself off the sending unit. If you have a dummy-light to begin with then you would splice into the sending unit wiring to ground the buzzer.
The temperature gauge would be more complicated - you can't tee off of a temperature gauge because the probe for the gauge has to be in the flow of the fluid. If your temperature gauge is mechanical, I'm not sure what you'd do. If you have an electric temperature gauge, you'd have to rig up a small but clever electronic circuit to trigger a buzzer once the sending unit resistance reaches a certrain value.
All in all, a lot of work. Easier just to not let her drive the truck especially if she has already wrecked hers (sorry, just teasing). Seriously though - I personally wouldn't lend out my own vehicle to someone that doesn't watch the gauges. Give'r a ride instead. My .02
Old Dec 10, 2007 | 05:28 PM
73f100shortbed's Avatar
73f100shortbed
oops double post
Old Dec 10, 2007 | 05:29 PM
73f100shortbed
Pretend it won't start then giver her the number for rental car company.
