Cab mounts 50f1 ?
Old Dec 10, 2007 | 12:18 PM
RUSTY50F1's Avatar
RUSTY50F1
Cab mounts 50f1 ?
I sat the cabon the frame, but I have a gap between the cab and the frame. About an inch. When I took the cab off the frame I didn't see any kind of a rubber pad or anything else there. Is there a pad that goes there or what's the deal with the gap. Any one know what I should do.
Old Dec 10, 2007 | 12:41 PM
bobj49f2's Avatar
bobj49f2
The cab should sit off the frame. I just looked my F-4 and there is a 1/2" gap but I don't have my rear cab mounts bolted to the frame year. You have to have some space for movement and to clear the seat brace that runs under the cab.
Old Dec 10, 2007 | 01:17 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Rusty,
Yup, there should be a gap between the cab and frame. As Bob mentioned the cab "rides" over the frame, or at least at the rear it does. There is a small rubber spacer on the front cab mounts, maybe 1/4" thick at the most.
Bobby
Old Dec 10, 2007 | 09:05 PM
RUSTY50F1's Avatar
RUSTY50F1
Do I bolt it down tight? Or is there a steel spacer through it. If I bolt it in tight It pulls the cab down to it.
Old Dec 10, 2007 | 09:20 PM
Fomocosho's Avatar
Fomocosho
The 2 dog bone arms hold the back of the cab up a little. There are small rubber pads in the front with some shims if needed.
Old Dec 10, 2007 | 09:26 PM
RUSTY50F1's Avatar
RUSTY50F1
I found a mounting kit from LMC for $43.00 for the rubber mounts, steel plates, and nuts and bolts. Does that sound about right.
Old Dec 10, 2007 | 11:05 PM
rhopper's Avatar
rhopper
Rusty, I'd replace all the mounts with the LMC kit. I chased a front fender height problem for a week before I found that the rear mounts let the cab tilt slightly. The drivers side of the cab was 1/2" lower than the pass, and it made quite a difference in the side to side height of the front clip.
Old Dec 10, 2007 | 11:18 PM
RUSTY50F1's Avatar
RUSTY50F1
Thanks rhopper I'll just order the kit and replace them all so I don't have to worry about it.
Old Dec 10, 2007 | 11:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I have this EXACT situation, my driver's side fender is 1" lower than the right, with brand new dogbones. I will have to check the front mounts.. Good tip!
Old Dec 11, 2007 | 09:59 AM
bobj49f2's Avatar
bobj49f2
I don't know if you need this info but since I have it I thought I would post it:
The red parts have a rubber pads between it and the cab. The purple part is the "dog bone" brace. There is a rubber block that goes between the "bone" and bracket that it bolts to. If you have the original "bone" and it's worn out they make reproduction parts. The new one are different than the originals. They're not stamped metal, they're cast iron:
Old Dec 11, 2007 | 12:03 PM
firstrider's Avatar
firstrider
Some what of a related queston ? Have a 3/4 " space at inside of headlight panel where fender meets but where the radius starts on the outside of headlight panel the fender matches fine . Any of you have a thought on this ?
Old Dec 11, 2007 | 12:04 PM
RUSTY50F1's Avatar
RUSTY50F1
Thanks Bob I can use that pic. I couldn't find the one I had.
Old Dec 11, 2007 | 12:17 PM
bobbytnm's Avatar
bobbytnm
Thanks everyone!! Great info here (I think my cab is not setting right either)
firstrider -- Any chance of getting a pic of the effected area? I'm having a hard time picturing it
Bobby
Old Dec 11, 2007 | 12:24 PM
RUSTY50F1's Avatar
RUSTY50F1
By a space do you meen the fender looks like it's 3/4 inch to far forward, or to far back?
Old Dec 11, 2007 | 01:26 PM
firstrider's Avatar
firstrider
The affected area shows the fender 3/4" too high . All the other areas gravel pan , lower et. panel & etc. line up . Could the fender in that area be that whacked ? The headlight panel matches up every where else . Unfortunately found this out after after fender received final paint . There is no way headlight panel will raise that far .This has me stumped . All panels fit perfect on pre assembly . Help !!
