Starter Replacement Advice
Old Dec 10, 2007 | 07:49 AM
Capt.Schenk's Avatar
Capt.Schenk
I'm looking at replacing my starter with "Higher Torque" starter from DB Electrical off of Ebay. It was recommended to me from a memeber of this board, but I wanted to know if anyone else was using one of these. Also, how hard is it to replace the starter on these trucks? (2000 F250)
Old Dec 10, 2007 | 08:39 AM
Smokin''s Avatar
Smokin'
Smokin
Captain,
Not sure what to tell you on the high torque starters...i've heard a lot about them but I just changed my starter out and decided to go with standard Motorcraft.
The starter's on these aren't hard. It's located right next to the oil pan on the starboard side. It's a standard three big bolts, battery connection and live wire which is a really tiny 8 MM I believe. The big bolts are 18MM. Just make sure you disconnect your batteries before pulling out the old starter unless you like the smell of burning human hair.
The only real trouble I had was getting up in there to get the top bolt out..and you may need an open-ended 18MM. My truck is lifted and I had to squeeze myself in between the tire, leaf spring and frame sitting on my butt inside the wheel well to get the leverage I needed...but I do have short arms and had to use my 18MM socket so it wasn't an easy job trying to do it lying on my back.
Old Dec 10, 2007 | 09:33 AM
Capt.Schenk
Thanks for the help and advice. What did you pay for the Motorcraft?
Old Dec 10, 2007 | 09:56 AM
Smokin''s Avatar
Smokin'
Smokin
About $200, mechanic's cost.
Can get a Mitsubishi or Nippondenso rebuild at a parts store for just about that price.
Old Dec 10, 2007 | 10:02 AM
Capt.Schenk
The reason I was asking about the price is because the "higher torque" starter I found online is $130 + shipping. If I have it over-nighted, I'll pay about the same price as I would buying a motorcraft.
Old Dec 10, 2007 | 01:35 PM
nightskyisme's Avatar
nightskyisme
Can you send me the link or more info. on that hi-torque starter? I would like that for mine. Please let me know if you get it and how it performs. Thanks
Old Dec 10, 2007 | 02:06 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Make sure you use the red locktite on the threads, I had one of my starter bolts back out on me and I chewed up my starter.
Old Dec 10, 2007 | 02:12 PM
UP_There's Avatar
UP_There
if your truck is lifted.....the hardest part of the removal/install is finding the right position to sit up....and fish your wrench around finding the top bolt to remove. It was very uncomfortable for me.....but the starter install/removal part is EASY. Just unhook battery...and there's 3 bolts.
Old Dec 10, 2007 | 02:13 PM
Capt.Schenk
Here's the link: http://cgi.ebay.com/ebaymotors/NEW-F...QQcmdZViewItem
The guy selling these recommended a Denso high torque starter, but I didn't see them in his online store.
Old Dec 10, 2007 | 03:12 PM
Smokin''s Avatar
Smokin'
Smokin
It say's it'll replace the 3 bolt starter...but I don't buy it it doesn't even look like it will fit. Looks like it's an ambulance package starter or something.
Here is what your stock unit looks like...
http://www.dieselfiltersonline.com/S...r-Str7006.aspx
I'd like to hear from someone who has replaced their OEM starter with one of these dudes.
Old Dec 10, 2007 | 03:20 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
i got one of those ebay jobs, and its great!!!!!!, it man handles the motor. belive me, thats the same guy i got it from ,DBelectrical, fast shipping too. love it, the only problem i had was the maion power wire has 90* bend in it and i had to make it straight for this one to fit, which was no problem.
Old Dec 10, 2007 | 03:29 PM
Capt.Schenk
Pete's the guy who told me about this starter. (Thanks for posting Pete, I couldn't remember who turned me on to this deal) How long have you had this starter?
Old Dec 10, 2007 | 03:38 PM
PETE'S_6.0PSD
it will be around a year now, no problems so far. i would recommend it to everyone.
Old Dec 10, 2007 | 03:44 PM
Craig64's Avatar
Craig64
Looks like it hangs a little lower than the OEM? Any issues there?
Old Dec 10, 2007 | 05:14 PM
Capt.Schenk
I hope there isn't any issues because I just ordered mine and I don't have a lift. $153 with ground UPS shipping.
