need help !!!! code 22
Old Dec 9, 2007 | 09:12 PM
ricksan's Avatar
ricksan
Unhappy need help !!!! code 22
91 explorer xlt...check engine light on...code 22 KOEO...pointing to map sensor.. I am sure I have a MAF sensor, is map and maf the same? Been researching, some says 91xlt has a map, some says it has maf.. can i have both map and maf sensors? please help...
Old Dec 9, 2007 | 11:40 PM
mrshorty's Avatar
mrshorty
From what I understand, your '91 has both -- sort of. You don't really have a MAP, you have a BAP (Barometric air pressure) sensor. A BAP is exactly like a MAP except that the BAP isn't hooked up to the manifold. It is simply open to measure ambient air pressure. The MAF is the important sensor as far as driveability.
Start by going over the wiring between the BAP and the PCM, and then test the BAP.
