Truck bucks
Old Dec 9, 2007 | 09:09 PM
wagontrainer's Avatar
wagontrainer
Truck bucks
I have a 1971 F100 that i just put back in service.I did a complete brake job(shoes,springs,wheel cylinders,rubber brake lines,master cylinder and turned drums) on the truck and when i apply the brakes the truck wants to buck.The truck was out of sevice since 1999 and i can remember it did this back then with the old brake setup.Any idea what might be causing this?Any help would be appreciated.
Old Dec 10, 2007 | 08:36 AM
blue68f100's Avatar
blue68f100
Did you adjust the shoes up properly with the star wheel one you installed the wheels?
Old Dec 10, 2007 | 08:45 AM
68horses's Avatar
68horses
wagontrainer,
Sounds like the first place to look would be I-beam and strut bushings and kingins. You might also check for a bent wheel/rim or bad tire. Try having someone else roll the truck and watch the tires from front and then rear.
Gene
Old Dec 11, 2007 | 11:14 AM
wagontrainer
I have not taken a lot of time adjusting the brakes just backing up and applying the brakes for self adjustment.
Old Dec 11, 2007 | 11:19 AM
wagontrainer
[QUOTE=68horses]wagontrainer,
The passenger side king pin had a little slack in it but the drivers side was tight.The tires are new and the rims are staight.How can i check for slack in the i-beam and strut bushings?
When i apply the brakes you can feel it in the pedal.
rummur s.c.
Large Truck
May 4, 2011 10:03 PM
fwerring
Aug 31, 2010 03:52 PM
buck2233
Dec 16, 2006 03:07 PM
51truck
Feb 3, 2003 07:56 AM
Kikker
Sep 6, 1999 06:26 AM
