Sponsored by: Auxito
Fog light wiring
Old Dec 9, 2007 | 07:27 PM
scratchy87's Avatar
scratchy87
Fog light wiring
My '98 F150 didn't come with fog lights. I have installed two that i aquired, but i want to wire them into my incab headlght switch. It has the standard ford headlight swtich in it, with pullout fog light activation, but i wouldn't have a clue how to wire it to my fog lights. I want to make sure they turn off when the high beams are on. I'm new at this stuff, but i want to learn all i can and make sure i do it right. Any help will be appreciated.
Old Dec 12, 2007 | 09:16 AM
KingRanchMan02's Avatar
KingRanchMan02
Hello scratchy87 and welcome to FTE! Although I don't have an answer for you right now, someone else should chime in soon. Good luck on getting this done!
Old Dec 12, 2007 | 08:24 PM
Smaug's Avatar
Smaug
Foglight wiring is already there. But you'll need a new switch. Your switch doesn't have the parts to turn the lights on even though it will pull out.
Old Dec 13, 2007 | 09:56 PM
scratchy87's Avatar
scratchy87
I couldn't find the wiring. it' looked like it should have been obvious, but i'm pretty good at missing what's right in front of my eyes. the switch is easy, if you could tell me where the wires are, the rest is a piece of cake.
Old Dec 15, 2007 | 12:58 AM
stormchaser1's Avatar
stormchaser1
this may or not be it, but i don't have fog lights either
and i was looking to do the same i spotted a empty harness
on the passenger side behind the bumper, like i said this
might or nor be what your looking for
Old Dec 15, 2007 | 10:38 AM
galaxie641's Avatar
galaxie641
I was going to wire my aftermarkets into my stock harness to use the stock switch to activate the relay. I still haven't gotten around to it but from what I remember the stock foglight plug is seen here above the oil filter and is basically in the same place on the other side. They are easy to see with the bumper off but damn near impossible to see with it on.
tvannaman2000
Sep 21, 2014 04:10 PM
skinner24
18
Sep 11, 2014 06:57 PM
cutlass
Oct 22, 2011 11:14 PM
Mitch1407
Aug 19, 2011 08:30 PM
leon45
1983 - 2012 Ranger & B-Series
Apr 23, 2004 10:11 AM
