First Post: Many questions
Old Dec 12, 2007 | 12:43 AM
multisonic's Avatar
multisonic
Question Xbfh
Originally Posted by baddad457
I'd like to have seen that trick. Only way I can think of that being accomplished is with the XBFH method.
hit the b***h f****N hard?
that would explain why the outermost edges of the bearing were worn from hand turning the crank. the bearing was concaved on the wear surface because he forced it in.
maybe he thought it was a chevy?
Old Dec 12, 2007 | 05:34 AM
baddad457's Avatar
baddad457
You got it.
Old Dec 16, 2007 | 02:07 PM
multisonic's Avatar
multisonic
well the motor is in the truck, bolted up to the bell housing and mounts and all that. so i went out this morning to put on the 4 TC nuts. i slid under the truck and put on the first nut. as i tighetend it i thought the rotational force of the nut being tightened would naturally turn the flexplate so i could access the other nuts. not so much. so i hooked up the battery to the starter and CLINK! nothing. it's locked up again!
i know the motor was spinning free when i put it in. any ideas on what it could be now?!
i gotta go to work and defend the nation and things i hope there are some helpful comments for me tonight. thanks!
...frustration...
Old Dec 16, 2007 | 02:21 PM
HemiEater's Avatar
HemiEater
did you have to force the bellhousing to the engine block with the bellhousing bolts, or did it slide tight up against the block. the way it is now can you move the converter at all. loosen that one nut you got in there and see if you can push the convereter back away from the flexplate.
Just thinking you might not have had the converter seated all the way into the pump....
Old Dec 16, 2007 | 03:45 PM
baddad457's Avatar
baddad457
And if the torque converter wasn't seated right, you may have broken the front pump gear the convertor slides into.
Old Dec 17, 2007 | 12:41 AM
multisonic's Avatar
multisonic
it went together smooth all but the last 1/2 to 3/8 of an inch and i just brought it together with the BH bolts, that a bad thing?
Old Dec 17, 2007 | 05:31 AM
HemiEater's Avatar
HemiEater
sorry ...but I don't think you had the converter seated all the way into the pump. loosen the converter nut you have on it and see if you can move the converter....
Old Dec 17, 2007 | 08:18 AM
baddad457's Avatar
baddad457
Yea, that last distance is the most critical, the pump gear the convertor engages is a hard, but brittle piece, it doesn't take much force to shatter it. C-4's are the worst about this. If you have a C-4 and you had to pull both together like you did, I guarantee, you've broken the pump gear.
Old Dec 17, 2007 | 02:11 PM
multisonic's Avatar
multisonic
i just thought it was the alignment studs being a B.... so what do i do now? and how much does a pump gear or new converter cost?
.......RATS!
Old Dec 17, 2007 | 02:23 PM
HemiEater's Avatar
HemiEater
OK one more time ...can you move the converter... you should be able to move it (in and out) and back and forth..... it should be loose with it un-bolted
Old Dec 17, 2007 | 08:31 PM
baddad457's Avatar
baddad457
Well if the engine will freely rotate, you can try firing it off and see if the transmission operates normally. But if not, then you'll have to pull the transmission and change the front pump (or maybe just the gear, you'll have to consult a better transmission guy about this) When the convertor is seated all the way into the pump, the studs on the front of the convertor will just fit behind the flexplate and you'll be able to rotate the flexplate to the point where the studs line up with their holes. Then you'll be able to pull the convertor studs into those holes to start the nuts.
Old Dec 18, 2007 | 01:59 PM
multisonic's Avatar
multisonic
well i am getting pretty good at pulling the motor out. took me an hour this time. ha ha.
anyway i pulled the TC but I dont know what signs to look for. is the pump gear the big (outer) or little (inner) shaft on the trans or is it in the converter?
thanks for helping me through this dad and eater...
Old Dec 18, 2007 | 02:38 PM
  #28
baddad457's Avatar
baddad457
To see it, you'll have to remove the bolts in that dark looking center casting that the convertor hub fits into. The front part should come off, exposing the gear inside. If it's broken, it'll be obvious.
Old Dec 18, 2007 | 03:07 PM
  #29
HemiEater's Avatar
HemiEater
heres a few pics I found
http://cgi.ebay.com/ebaymotors/Ford-...temZ4589053781
Old Dec 28, 2007 | 08:08 PM
  #30
multisonic's Avatar
multisonic
so it's all good in the hood. everything works and drives and all is well except TIMING. theres no timing tab where it's supposed to be. it's not like my 318 that was stamped on the cover. theres supposed to be a tab or something? how can i set the timing now that the tab is missing/gone or whatever the previous owner did with this crucial part?
