Offroad & 4x4
trans/tcase identification
Old Dec 9, 2007 | 01:02 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
can anyone tell me what tcase and tranny i have sitting in my garage?
Old Dec 9, 2007 | 01:12 PM
MBBFord's Avatar
MBBFord
A NP205, and to tell the truth, I don't know(T18 or T19 or Np435).
Old Dec 9, 2007 | 01:17 PM
quadzjr's Avatar
quadzjr
hmmm....ok
it looked different from my other 205 so i wasn't sure...
Old Dec 9, 2007 | 01:21 PM
MBBFord's Avatar
MBBFord
The small little metal circle next to the rear yoke is a dead give away. It has the different style shift linkage between the shift rails(no many had that particular kind). It also has the 8 3/4" adapter.
Old Dec 9, 2007 | 01:26 PM
1EVILCREWCAB's Avatar
1EVILCREWCAB
you've got a t-18 and 205 out of an f-250, a 79 to be precise
Old Dec 9, 2007 | 01:27 PM
quadzjr's Avatar
quadzjr
thanks, may be another dumb question but is the t-18 a good tranny?
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Warner Transmissions: The cup (8MTH-7220) that holds the shift lever to the transmission shift tower screws off/on.
New Process: The cup (B8T-7220-D) that holds the shift lever to the tower is retained by two pins that protrude from the tower. The cup twists off/on by a 1/4 turn...and is usually buggered.
Old Dec 9, 2007 | 01:29 PM
1EVILCREWCAB
its all right, about the same as np435, could also be out of a 79 bronco
Old Dec 9, 2007 | 03:52 PM
teds74ford's Avatar
teds74ford
Looks exactly like my T18/205 combo. One advantage the 435 has is a lower first gear. Other than that, the T18 is just fine.
Old Dec 9, 2007 | 06:01 PM
STGFordCrazy04's Avatar
STGFordCrazy04
Junk! I might be interested if you want to sell it
Old Dec 9, 2007 | 06:04 PM
godblessmud's Avatar
godblessmud
for future reffernce heres a very useful site to identify trannys
http://www.motivegear.com/tech_info/...nny_guide.html
Old Dec 9, 2007 | 06:13 PM
STGFordCrazy04
I like this one too
http://www.novak-adapt.com/knowledge...on_gateway.htm
Old Dec 9, 2007 | 06:15 PM
quadzjr's Avatar
quadzjr
ill sell it...
Old Dec 9, 2007 | 06:17 PM
STGFordCrazy04
Im sending you a PM
Old Dec 9, 2007 | 06:25 PM
STGFordCrazy04
delete some so it will go through
