old inline 6
Old Jul 31, 2001 | 04:36 AM
walterdanek's Avatar
walterdanek
old inline 6
Old Aug 2, 2001 | 01:45 PM
briandd1's Avatar
briandd1
old inline 6
I have an engine off an old ford 8n. Its a funk conversion to a 6 cylinder. I need a rebuild kit for it (Pistons, sleeves, seals, bearings, whatever comes in a rebuild kit). On both sides of the block, there is a piece of metel pressed onto the block that says "L141". On the right side (looking from the fan) it says either FERRO or FERRS. It also says 1HA-6015A on the same side. Does anyone know where I could get a rebuild kit and maybe a manual for this engine?? How can I tell if this engine is a ford???
Thanks,
brian
Old Aug 2, 2001 | 02:17 PM
jwtaylor's Avatar
jwtaylor
old inline 6
Try cliffordperformance.com You may want to give them a call for info on what motor you have they are very knowledgable. As far as buying a rebuild kit that is up to you. You could find rebuild kits anywhere. Jcwhitney, PAW, clifford, etc.. Good luck
Old Aug 2, 2001 | 08:26 PM
82F100SWB's Avatar
82F100SWB
old inline 6
[font size="1" color="#FF0000"]LAST EDITED ON 02-Aug-01 AT 09:27 PM (EST)[/font][p]Well, JW, I hate to tell you, but the folks at Clifford or any of those places won't know that engine for a hole in the wall, if it is a Funk conversion, it's a 95 hp industrial engine(yes, 95 hp in a 20 hp tractor...) Brian, go to www.ytmag.com, that's where the tractor guys hang out, someone on the Ford N board should be able to steer you the right way.
Good Luck
Evan MacDonald
82 F100 FlareSide 2wd
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
SBC valved 66 240 head
Headlight Relays - Delanty Style
NP435(6.69 low)
3.55 Geared ARB'd 9"
31x10.50/15 Cooper Discoverer LT's
Old Aug 2, 2001 | 09:45 PM
jwtaylor's Avatar
jwtaylor
old inline 6
Your right I wasn't familiar with what he was asking.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
