flaring brake lines
Old Dec 7, 2007 | 10:26 PM
bliss1's Avatar
bliss1
flaring brake lines
ok, ive been trying to flar a brake line for several days. my problem is that i cant get the darn thing to flar center. if tried about 10, 15 times, is it just me or what.
Old Dec 7, 2007 | 10:40 PM
Putt's Avatar
Putt
A couple thoughts:
1. The end of the tubing has to be PERFECTLY straight and free of burrs.
2. The tubing has to protrude through the yoke the proper amount(double flaring set should show how).
3. You are using a double flaring set, right?
Old Dec 7, 2007 | 11:08 PM
bliss1's Avatar
bliss1
ive done all the above, and had someone else try it with the same results.
Old Dec 7, 2007 | 11:14 PM
Putt's Avatar
Putt
Cheap flaring tool? Or maybe something is wrong with it? I am fairly good at double flaring(years at an old style parts store where we would flare the lines if needed) and I still have to practice a couple before they start turning out well. It is not easy to explain the process, but easy to learn by watching.
Old Dec 7, 2007 | 11:28 PM
bliss1's Avatar
bliss1
my thought was the tool as well. i dont how to tell a ceap one from a good one, except for price. maybe ill go to Midus and see if they can flar them for me.
Old Dec 7, 2007 | 11:40 PM
Rosati's Avatar
Rosati
You should also use a lube (motor oil is fine) on the anvil and tube. Be sure to lightly bevel the outside edge of the tube.
Most budget flaring kits do not hold the tube well, so I usually shave a little of both clamp edges (the edges with the half circles in them) on a belt sander.
Old Dec 8, 2007 | 12:36 AM
bigblockford79's Avatar
bigblockford79
I had a similar problem with my flaring tool that I bought a few months ago. I finally fixed my problem by sticking a little extra line through the clamp when I put the first flare on. Also, experiment with different amounts of inside flare. It may not always be necessary to "bottom out" the die to form the inside flare.
Old Dec 8, 2007 | 07:52 AM
thomc's Avatar
thomc
I've owned several double flaring tools , but never had one that worked well until recently. I bought one at O'Reilly's auto parts for 19.99. It works great every time. I had gotten to the point that I dreaded trying to double flare brake lines so much I had used lines that were too long by putting extra bends in them to take up the "slack". No more , now I don't mind using the new tool and have even flared some pieces of left-over tubing I had stashed back. Remember to put the nut on before you make the second flare . Don't ask . I can't remember the brand name or part number of the tool I bought right now, but I think all O,Reilly's stores have the same parts , regardless of location. Let me know if you don't have an O'Reilly's near you and I will try to help you. Happy motoring to you and your'n. Tom.
Old Dec 8, 2007 | 02:40 PM
bliss1's Avatar
bliss1
no O'reilly's near me. i leave in n. cal.
Old Dec 8, 2007 | 05:26 PM
GLR's Avatar
GLR
A bevel on the outer edge helps.
Old Dec 8, 2007 | 05:50 PM
blue68f100's Avatar
blue68f100
My set is made by Rigid, 3/16-5/8". Works every time for me, if I use the gage blocks.
If you use SS tubing you do not need a double flare.
Make sure the flaring head floats freely, grease th contact point. The body of the flare to tubbing holder should be fully locked in place. If it's allowed to float (move) it will not be centered. Which is what you are saying off centered.
My set also has a gage block for setting how much tubings needs to be extended to make the flare. Try only sticking up a very minimal amount of tubing at a time and see if it helps. Normally needs around 1/8" or less, did not measure mt gage blocks.
Old Dec 8, 2007 | 07:29 PM
bliss1's Avatar
bliss1
ill paly around with some scrap(lot of that) and see what i come up with.
Mstewart
6.7L Power Stroke Diesel
13
Jul 16, 2012 11:52 PM
GAF250_AF
Jul 7, 2010 10:01 PM
66sprintw53
Aug 25, 2004 10:23 AM
79CEEJAY
Mar 19, 2004 05:05 AM
