Sponsored by: Auxito
all windows steaming up
Old Dec 7, 2007 | 08:37 PM
siders2000's Avatar
siders2000
I have a 1997 Ford 150 Lariat. Recenty put a new radiator in it. Since then all the windows steam up when using the heater. The heater core is about 4 years old. Any ideas?
Old Dec 7, 2007 | 08:52 PM
dlburch's Avatar
dlburch
either your A/C compressor is not drying the air with the defroster on or you have a leak either in the heater core itself or on of the connections under the hood (fluid would follow the heatercore pipes into the cab. Was the cooling system flushed or pressure tested along with the radiator replacment? Maybe it caused the heater core to fail...
Old Dec 7, 2007 | 08:56 PM
siders2000's Avatar
siders2000
the cooling system wasn't flushed or pressure tested. All of the windows steam up, even the back window.
Old Dec 7, 2007 | 10:25 PM
oldsub86's Avatar
oldsub86
Check and make sure you have not set the heater controls to recirculate. You need outside air coming in to avoid the windows fogging up. If you have not set the control to recirculate, you may have a problem with a control not opening a door in the heater system.
Randy
Old Dec 7, 2007 | 10:43 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
A white board eraser (the dry erase, erasers) are great for wiping off foggy windows without leaving streaks behind. That's my tip for the day
Old Dec 7, 2007 | 10:59 PM
siders2000's Avatar
siders2000
Thanks so much for all the advice, I'll give it all a try.
Karnivool
16
Feb 10, 2016 05:11 AM
PStruwing
Feb 12, 2012 02:12 PM
big red c222
2004 - 2008 F150
16
Nov 6, 2007 04:48 PM
neesie25
Sep 11, 2003 09:55 AM
88_150
Jan 16, 2003 08:51 PM
