1996 E350 engine problems
Old Dec 7, 2007 | 04:19 PM
lee5563's Avatar
lee5563
I have a 1996 e350 with a 5.8L engine. The truck has 312,000mi on it. Anyway I was going on a trip the other day and it drove great for 5 hrs then I went to pass a car and it just bogged down and spit and spudered for a min while I was coasting to the side of the road. After that I would get this evertime I excelerated to hard or just trying to go up an incline. I was almost home when it did it everwhere around town. In park it revs up fine but under load it split and boggs down with a small back fire here and there. I tried my uncles snap on tester on it and would not connect to the computer. OBD II connector under the dash would not work and the computer said to connect under hood but I could not find a connector under the hood. My uncle thought maybe a plugged cat? Any ideas on a problem or how to fix the computer connector.
Old Dec 11, 2007 | 02:51 PM
shawntxt's Avatar
shawntxt
Fuel Filter?
Old Dec 11, 2007 | 04:32 PM
Moore558's Avatar
Moore558
A clogged fuel filter or a fuel pump breaking down under load would be my first things to look at. Get a fuel pressure gauge and hook it up to the test port and see what your readings are.
Old Dec 11, 2007 | 07:32 PM
Clubwagon's Avatar
Clubwagon
No power to the OBDII connector is often a fuse. There is no other place to connect the scanner to. You really need to get the scanner to talk to it. The scanner's manual should be in the case and has a trouble shooting proceedure in it.
It could be a plugged cat. To check, remove the O2 sensor and install a pressure gauge. Most muffler shops have the necessary gauge. Or, take a rubber mallet and whack the bottom of the cat. If it rattles, its come apart and is likely the problem.
Other than that, fuel pressure, TPS, MAP sensor, etc... should all be checked.
Steve
'95 Clubwagon XLT
Old Dec 12, 2007 | 08:16 PM
mhg's Avatar
mhg
look under hood for a obd1 connector
it will be obd1 if you have sd injection
obd2 if you have mas air
wirelessengineer
Nov 10, 2015 09:34 AM
scooterspal
1983 - 2012 Ranger & B-Series
49
Aug 6, 2015 01:47 PM
benbuilder
20
Jul 8, 2015 04:58 PM
pfeifer5
1997 - 2003 F150
Jul 30, 2008 06:29 PM
chewyjackson
Dec 18, 2006 06:24 PM
