Dp-Tuner - grrrrr
Old Dec 7, 2007 | 05:26 PM
rbaker6336's Avatar
rbaker6336
Originally Posted by ron's power stoke
seems to me most people cant get the truck to start with chip in and the tunes wont work...
think I read somewhere it depends on where you put nostart
Old Dec 7, 2007 | 05:35 PM
countrycar's Avatar
countrycar
Jason is right on this one guys. Donot rub it, scratch it down to the copper. Silver conducts electricity better than copper. Country
Old Dec 7, 2007 | 05:57 PM
erik_bishop's Avatar
erik_bishop
well you can go here and find the installation instructions for your year truck and there is good pictures to follow, my chip came with these documents printed in the box.
there are pictures of properly cleaned pins and improperly cleaned pins to use as a guide
http://www.itpdiesel.com/store.php?docs=1
Old Dec 7, 2007 | 06:09 PM
badger2196's Avatar
badger2196
Originally Posted by countrycar
Badger, make sure the keys are out of the ignition, in your pocket on the your work bench etc. I know it's the obvious. But It happend to me. Yah get excited about the install and forget. I burned my Tuner and my computer both,$$$$. Just a reminder. Country.
Thanks for the reminder, but Jody's instructions were pretty clear about that so they were in my pocket the whole time
Old Dec 7, 2007 | 06:10 PM
monsterbaby's Avatar
monsterbaby
Erik you might want to read those directions again it specifically says that too much copper showing is wrong and could cause the chip to not seat properly and burn up both the chip adn the PCM and it will not be warrentied if this happens.
Old Dec 7, 2007 | 06:16 PM
erik_bishop
ya thats why i put the directions from Itpdiesel up a post or two ago, it a DP tuner document and is what he should go by.
Old Dec 7, 2007 | 06:17 PM
erik_bishop
ya thats why i put the directions from Itpdiesel up a post or two ago, it is a DP tuner document and is what he should go by.
Old Dec 7, 2007 | 06:22 PM
monsterbaby
Well your first post stated to remove ALL the silver and it specifically says NOT to do that.
Old Dec 7, 2007 | 06:23 PM
jhand124's Avatar
jhand124
Originally Posted by erik_bishop
i had a pic that showed the proper amount of cleaning you need to do on your pins and basically you need to scratch off all the silver metal and rub down to where all the pins on the board show brass, every single pin and both sides, it takes a while to do, if your finger tips don't go numb you are not done yet, and don't press too hard, you could crack the board.
Should just barly be able to see brass just fine scratches, the object is to remove the silicone.
Old Dec 7, 2007 | 06:28 PM
countrycar's Avatar
countrycar
He just made a mistake is all. It sounds like we all know what to do though. OH and in my case, what NOT to do also. HAH HAH HAH!! Country
Old Dec 7, 2007 | 10:05 PM
powerstrokinsmokin's Avatar
powerstrokinsmokin
I would just wait and speak will Jody or Diane, I have seen where there maybe a problem with programming in our shop (mack & Volvo) so maybe just maybe #5 position never got a program so it will not recognize and switch to that. Want settings did you get???
Old Dec 8, 2007 | 10:32 AM
badger2196's Avatar
badger2196
Well, tried again with no luck - now the WTS doesn't come on and the truck won't start. I fail to see how the connectors could be any cleaner than I have them, and I still can't get hold of Jody. Arrrggghhhh!
Old Dec 8, 2007 | 10:40 AM
  #28
rbaker6336's Avatar
rbaker6336
is the controller still blank
sounds as though the no start is working
Old Dec 8, 2007 | 10:52 AM
  #29
badger2196's Avatar
badger2196
Controller is still blank, but I don't have a no-start setting. Also, on the first install at least the truck started.
Old Dec 8, 2007 | 11:34 AM
  #30
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Don't get frustrated, you will get it right and I know Jody will make it right if there is a problem with the chip itself. In the end you will be laughing at this and grinning as you drive.
