99 explorer loud when driving
Old Dec 7, 2007 | 08:00 AM
tomo805's Avatar
tomo805
My explorer has developed a diesel-like sound while driving, that increases and decreases with the rpm's. This is driving me crazy. You can hear this over the radio. I thought that I possibly had an exaust leak or a heat shield rattling, so I took it in anf found the mounts for the muffler had broken loose. These were fixed and did not solve the problem. I'm also having loud noise which seems to be coming from the tires all of the sudden. This noise fluctuates with the speed also, ending when you roll to a stop. These tires are 6 months old. Help please.
Old Dec 7, 2007 | 09:06 AM
Backin72's Avatar
Backin72
Has regular maintenance been done? Tune up, plugs and wires? Check for vacuum leaks? Wheel bearings checked?
We need more info.
Old Dec 7, 2007 | 11:08 AM
Bear River's Avatar
Bear River
Former ******
Wheel bearings can make a clicking noise when they go bad, any auto mechanic can check those and make sure they are good. A rattle noise, that sounds like marbles in the engine, is know and pinging. It usually indicates that fuel with too low an octane rating is being used (use 87), a tune up is needed, build up in the combustion chambers is increasing compression, or a host of other things. We really need more infomation from you to point you in the right direction.
Old Dec 7, 2007 | 01:01 PM
tomo805's Avatar
tomo805
The noise from the tires does not seem like a bearing issue, more so like off- road tires would make.
The plugs and wires have been changed, in the last 2 years, probably 20,000 on them. the only thing that has not been changed is the fuel filter. I tried to change it and had no luck removing the old one. When I had the muffler re-attatched, they tried and could not remove the old one. They said I should take it to the dealer. I have 100k on the Explorer and realize that the filter needs changed. I have always used 87 octane but this noise has just recently started.
Old Dec 7, 2007 | 01:15 PM
Backin72's Avatar
Backin72
Try cleaning the MAF(mass air flow) sensor.
Here's a link.
http://www.explorerforum.com/Singlet...ages/ping.html
Old Dec 7, 2007 | 01:18 PM
merlynr's Avatar
merlynr
My 99 had a lot of tire noise after the tires got about 80% worn out. Was bad between 20 and 40 mph and when I got new tires last week and an alignment(toe end was out) and put on new LH upper ball joint the noise went away. 135k miles
Old Dec 7, 2007 | 05:49 PM
steve(ill)'s Avatar
steve(ill)
bad wheel bearings on the new explorer dont sound like marbles... they sound like a big 4 x 4 with oversize off road tires driving down the street, you will hear a whiinning noise that starts at 10 MPH and gets louder and more "whine" as you speed up--- thats my bet.
Old Dec 7, 2007 | 11:04 PM
tomo805's Avatar
tomo805
That may be the noise from the tires that I am hearing but the diesel-like noise increases and decreases when I accelerate or let off the gas. maybe I have 2 problems.
Old Dec 9, 2007 | 03:49 PM
danger95's Avatar
danger95
you might wanna check out the hub assembly sounds like what was wrong with mine, fixed it right up, installed was 379.00
Old Dec 14, 2007 | 03:25 AM
54Guy's Avatar
54Guy
Danger 95. WHAT was wrong with your hub assembly? And WHAT did you do to it? HOW do I "check" it? I am having a similar problem! Thanks!
Old Dec 14, 2007 | 05:19 AM
danger95's Avatar
danger95
i bought the part and a friend is a machanic , had him fix it! you could really hear it when you turned to the right!
Old Dec 14, 2007 | 07:59 AM
steve(ill)'s Avatar
steve(ill)
the "HUB" fix, is replacement of the bearing. it normally comes as a kit, bearing and hub. the hub is not the real problem, the bearing inside has failed.
Old Dec 14, 2007 | 12:15 PM
danger95's Avatar
danger95
hub assembly
he replace the whole assembly, the noise is gone! it cost 175.00 for the assembly, the rest was labor!
Old Dec 14, 2007 | 04:49 PM
steve(ill)'s Avatar
steve(ill)
read this-- how to check bearings
https://www.ford-trucks.com/forums/6...?highlight=hub
Old Dec 15, 2007 | 12:04 PM
tomo805's Avatar
tomo805
I'm being told by the garage that my road noise sound is coming from the rear end. Sounds very similar to what I read from the link above. I'm hoping that it just needs new rear bearings.
