Sponsored by: Real Truck
Sucks in snow
Old Dec 7, 2007 | 06:18 AM
harstad23's Avatar
harstad23
Sucks in snow
My '05 sucks in the snow. I had to put it in 4 Low to get it up my driveway which is not hardly steep at all. In my '00 I had a limited slip and I thought I had one in the new one, but Im not sure I do. How do I check without looking? Door codes or VIN?? Thanks.
Old Dec 7, 2007 | 06:38 AM
npccpartsman's Avatar
npccpartsman
door code will give you the axle type and tech folder will tell you what it is.
Old Dec 7, 2007 | 06:50 AM
chuck06250's Avatar
chuck06250
Check the door code, and then the post at the top of the page entitled "Read First".
A bit of weight in the bed wouldn't hurt.
Old Dec 7, 2007 | 06:52 AM
ford390gashog's Avatar
ford390gashog
The axle code will have a letter before the number indicating a limited slip like "H9" .
Old Dec 7, 2007 | 07:16 AM
m350's Avatar
m350
What ya got for tires on the truck ?
Old Dec 7, 2007 | 07:24 AM
PowerStrokeHD's Avatar
PowerStrokeHD
That is the first question that popped into my head. If they are factory Conti's the issue is probably more to do with the tires then the limited-slip.
Old Dec 7, 2007 | 07:25 AM
harstad23's Avatar
harstad23
stock. half the reason it sucks.
Old Dec 7, 2007 | 07:38 AM
Super08's Avatar
Super08
If you have the 18" Conti's, that will be your problem. They are hopeless in the snow.
Old Dec 7, 2007 | 08:02 AM
wwb's Avatar
wwb
Originally Posted by harstad23
..... I had to put it in 4 Low to get it up my driveway which is not hardly steep at all......
Traction is determined by several factors... limited slip, locker, or open differential; what kind of tires with how much tread left; weight distribution (if you're not driving all the wheels).
High/Low range isn't going to matter unless you're trying to run an F250 up the grade using a 3 hp Briggs & Stratton; low range will do absolutely nothing to increase your traction; it just makes more torque available at the wheel.
Old Dec 7, 2007 | 08:06 AM
RogueSpear2023's Avatar
RogueSpear2023
My friend at work has an 04 PSD 3.73 LS with factory tires on it, and they only have 20,000 miles on them and they suck even with weight in the back. He plows snow for a living and keeps getting stuck, he's replacing the tires today. I keep giving him crap because his is a 250 and mine is a 350, I keep telling it must be the 250, you should have gotten 350 because my truck works awesome in the snow even when pulling a trailer.
Old Dec 7, 2007 | 08:22 AM
ccerniglia's Avatar
ccerniglia
Post me your Vin# and i shall give you all the info you need about your truck.
Old Dec 7, 2007 | 09:09 AM
harstad23's Avatar
harstad23
1FTSW21P65EC09364
Thanks...
Old Dec 7, 2007 | 09:25 AM
UP_There's Avatar
UP_There
Factory tires aren't gonna do much in any amount of snow. F350 or F250......traction is the most important thing in snow....which isn't going to be accomplished with stocker tires.....unless it's dry pavement, but even slickies will work on that!
Old Dec 7, 2007 | 09:31 AM
DCSpecial's Avatar
DCSpecial
Yep, factory continentals suck......period.
Get some better tires (I like the Goodyear Wrangler Silent Armor) and you will get much better traction in the snow. I was driving around our shop in my 07 on solid ice in 2wd with my Silent Armors.
Hankook has a new tire (AT-M or something like that) that has a very aggressive tread for an all terrain as well. Looks like they would do well too. Seen them yesterday at my tire dealer since I was having them clean my 07.
Old Dec 7, 2007 | 10:03 AM
GregN's Avatar
GregN
I had Firestone Transforce tires on my truck last year and they weren't all that good. I put Michelin LTX M/S tires on a few months ago and WOW what a difference. The only bad part is that I can't do doughnuts in the same place for more than a few laps because the tread diggs down to the asphalt to quick. These tires work amazing!
The easiest way to tell if you have a limited slip (or if it is working) is to find a place that has hard packed snow, put it in 2WD and gun it. If you see two marks or your back end swings around then you have a locker/limited slip. If you have a one wheel wonder and just throws up a rooster tail on one side you have an open diff (or your limited slip isn't working).
