Sponsored by: Auxito
Noise ???
Old Dec 6, 2007 | 09:06 PM
Norfra's Avatar
Norfra
Question Noise ???
Hi Guys
I have a 1999 F150, 4.6 motor, 4x4 , auto
My question is when I accelerate i get this howling sound coming from the engine. I think??
Could this be my clutch fan??
Old Dec 6, 2007 | 10:20 PM
Ultramagdan's Avatar
Ultramagdan
Yes it could be. Has it just started or has it always done it?
Old Dec 6, 2007 | 10:51 PM
xjoedirt55x's Avatar
xjoedirt55x
does the sound go away after the truck is warmed up a bit or is it constant the whole time it is driving?
Old Dec 7, 2007 | 10:01 AM
Club Wagon's Avatar
Club Wagon
Only when you "accelerate" but not when you blip the throttle parked?
I ran a wild goose chase with a shreaking sound whenever the motor speeded up, moving or not. First idea was serpentine belt noise, but new belt changed nothing & old belt looked perfect. Suspecting the fan clutch, I took it off & ran the motor, again it changed nothing. Recommended replacement of belt tensioner & idler pulley also did nothing!
A tip is to spray the belt w/water while running, avoid the temptation to spray w/belt dressing or aerosol lubes which can damage the belt. Water immediately silenced my noise, but only for a few seconds-until it dried. However this confirmed the noise was generated by a belt issue.
I discovered the harmonic balancer had failed, even though I'd also run the motor w/o the belt on & it made no noise. The balancer relies on a rubber ring to precisely align the pulley on it's core. In my case the otherwise perfect looking pulley had spun & moved back toward the front of the motor ~1/8". Enough to cause the no longer inline AC pulley to protest loudly. Note that there was no sign of oil leakage & several veteran mechanics looked at it & missed it. My pulley was rubbing quietly against the motor, resulting in the belt being pulled rearward & out of alignment w/AC pulley, causing belt chirping at idle & wailing as the motor accelerated. Its still hard to believe such a seemingly minor misalignment could make so much noise.
Old Dec 7, 2007 | 07:23 PM
Norfra's Avatar
Norfra
Hi guys
It just started, change the belt, also if this helps the noise is always there, even when I am just idling ?????
Alleneoc
WTB - Parts & other
Oct 19, 2012 06:33 PM
minnesota4x4
Sep 10, 2007 11:15 AM
navyflyinggreg
Apr 24, 2007 02:04 PM
gotboostido
Mar 18, 2007 06:43 PM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
