carbed 300 owners
Old Aug 20, 2001 | 01:22 PM
jwtaylor's Avatar
jwtaylor
carbed 300 owners
I had a thought, I have these dual exhaust manifolds off my 95 truck and people with carbed motors seem to like these as an upgrade to their exhaust system. On ebay they are going for well over a $100 dollars. Here is a thought I could use some 19 lbs v-8 injectors so if anyone has a working good set and no use for them how about a trade. Just a thought
Old Aug 20, 2001 | 04:48 PM
tetraruby's Avatar
tetraruby
carbed 300 owners
There's a slight obstacle...on older trucks like my '79 there's a pipe that plumbs exhaust from the exhaust manifold into the EGR plenum. Changing the plumbing can alter the backpressure necessary to run the EGR correctly - at least those of us that have strict emissions to comply with. Incedently, how do the FI 6's route exhaust gas into the EGR?
Old Aug 21, 2001 | 09:56 AM
jwtaylor's Avatar
jwtaylor
carbed 300 owners
If you are facing the exh. manifolds from the side of the motor then it is the left one with a bung or whatever you want to call it going into the left side of it. A person could make something work with a little creativity. You could go to a junkyard and get the efi smog tube and large nut that adapts it to the exh. manifold probably cheap cut the efi egr crap off and then weld it to the tube from the carbed egr I am not certain but I would think this would work. Give it a thought
Old Aug 21, 2001 | 02:21 PM
whittey's Avatar
whittey
carbed 300 owners
