General Automotive Discussion
Snowplow Help!
Old Dec 6, 2007 | 07:57 PM
Loud & Proud's Avatar
Loud & Proud
Talking Snowplow Help!
Hey everybody! I've got an older, I believe, Western plow setup I'm trying to get working. I say Western because it's red and I can't find a company name on it. Anyhoo, it's a cable controlled motor and I was wondering if, at some point, it's supposed to shut off so it doesn't over heat when in use.
I was trying to adjust the cables right tonight but was having some trouble and it kept running and I ended up unhooking it when the little trails of smoke started coming out of it:-) It was quite aggravating. LOL
I wasn't sure if it's supposed to shut off or go into a bypass mode or something when it's at full float or if there's something wrong with it. The only other connections running to it besides the control cables are the pos. & neg. wires. I didn't really want to keep smoking it to find out. I appreciate any help or suggestions! Take it easy all and have a very Merry Christmas!
Old Dec 6, 2007 | 08:45 PM
DPorter's Avatar
DPorter
No the motor should stop running when the control is released to center.
The western web site should have the manuals available to down load to tell you how to service this unit.
Old Dec 6, 2007 | 09:38 PM
Loud & Proud
I thought that was the case. Thanks DPorter, I appreciate the advice. I didn't even think to check their website
Old Dec 6, 2007 | 10:08 PM
DPorter's Avatar
DPorter
was just looking at it myself. westernplows.com under publications conventional cable operated. Short or long version mechanics service manuals.
Old Dec 6, 2007 | 10:10 PM
DPorter's Avatar
DPorter
The most likely cause of the run on motor is the controller was not centered in the box.
This would continue to supply ground to the solenoid causing the motor to keep running.
Old Dec 6, 2007 | 10:26 PM
ageel's Avatar
ageel
These forums are a great source for help (much like FTE) when it comes to all things plowing.
http://www.plowsite.com
http://www.letstalksnow.com
Old Dec 7, 2007 | 11:04 AM
cdrmotorsports's Avatar
cdrmotorsports
Plowsite is a great place to get help with anything snow plow related.
Old Dec 7, 2007 | 04:57 PM
Autoglass's Avatar
Autoglass
Why have just a plow,,, When you can have a powerfull unit to do the job in style!
Old Dec 7, 2007 | 05:00 PM
andym's Avatar
andym
Now THAT is cool.
Old Dec 7, 2007 | 05:17 PM
Autoglass's Avatar
Autoglass
If you really want to see some real powerful units,,, Do a search for V8 Powered snowblowers! BTW,,, Don't shoot me for putting a CHEBY unit on here! AND,,, Theres a Hemi powered 1 too.
Old Dec 11, 2007 | 07:58 PM
Loud & Proud
Thanks for all the help and suggestions guys! Again, I appreciate all the input and the s/blower with the stacks is awesome! I learned alot from reading that mechanics guide and now I know what's wrong so, at some point, I have to get back to fixing it.
With my luck I'm going to end up running around in the dark with snow falling around me getting it going:-)
KsCop
Feb 21, 2021 02:19 PM
Frantz
Jan 25, 2017 07:22 PM
Jonnyfalcon
Jun 14, 2016 08:43 PM
weezer4117
Dec 30, 2014 09:46 PM
shins
Aerostar
Sep 29, 2003 02:30 PM
