Naw guys, you are all wrong... He ran out of blinker fluid!!!
Well you know if he ran out of blinker fluid then he may have to replace the flux capacitor fluid that runs the rest of the blinkers....once one goes bad it shorts out the others........Or maybe a bulb?
Check all bulbs on that circuit including brake, turn, parking, and even reverse before you go any further check the front as well. It happened to me out of state and I checked the bulb and it looked good but it still was happening so I went and replaced it. problem solved.
