Magnaflow vs. MBRP
Old Dec 5, 2007 | 11:31 AM
dmalmgre's Avatar
dmalmgre
Magnaflow vs. MBRP
So I'm trying to decide what exhaust I want. I know that the MBRP is cheaper and the quality is decent (I've installed a few 4" MBRP powerstroke kits). But on the other hand I've heard that the magnaflow 4" kit unleashes a few more horsepower and ft. lbs., is better quality, and sounds better. Also I've found some great deals on the 4" magnaflow kits. Anyone have any input?
Old Dec 5, 2007 | 11:38 AM
Joshua0606's Avatar
Joshua0606
Are you going with a muffler and a cat or delete pipes?
Old Dec 5, 2007 | 01:16 PM
dmalmgre's Avatar
dmalmgre
probably keep the muffler and get a delete pipe for the cat.
Old Dec 5, 2007 | 01:29 PM
Joshua0606's Avatar
Joshua0606
I personally have the factory pipe with the muffler and cat deleted. But I have some friends that run the MBRP and they sound great.
Old Dec 5, 2007 | 01:37 PM
dmalmgre's Avatar
dmalmgre
Can you get delete pipes for the stock exhaust?
Old Dec 5, 2007 | 01:46 PM
Joshua0606's Avatar
Joshua0606
I think you can get them from MBRP. I was able to find a exhaust shop that would do mine. It cost me $120 with a 5" tip.
Old Dec 5, 2007 | 01:50 PM
Joshua0606's Avatar
Joshua0606
Its call a muffler delete pipe and a cat test pipe.
Old Dec 5, 2007 | 01:58 PM
Lonewolftx's Avatar
Lonewolftx
Wink
TurboBack is the way to go . . .
Old Dec 5, 2007 | 02:20 PM
sourbeer's Avatar
sourbeer
Magnaflow
My brother has the MBRP turbo back on his 2003 6.0 and I got the Magnaflow installed on mine, turbo back system. cat delete, muffler installed system with 5" stainless rolled edge tip. I really like the sound of the Magnaflow, it howls when you mash down on the go pedal with a hot tune programmed in.
i don't think that you can go wrong with either one, the shop that I used preferred to use Magnaflow so that is what i went with. Nice install and it sounds great. I believe that the Magnaflow downpipe from the turbo is bigger than the MBRP.
Old Dec 5, 2007 | 02:25 PM
DSMMH's Avatar
DSMMH
I got a MBRP cat delete pipe and put it in my stock system. I just removed the two forward flange bolts, loosened the rear clamp and installed the delete pipe. It made a noticeable difference in reducing the turbo lag and the turbo whined a little more then stock. Then I got the MBRP T back 304 SS system which the previous cat delete pipe fit right in and that almost totally eliminated the turbo lag. Now when my turbo whines, heads turn. I'm very satisfied with the MBRP T back exhaust on my X.
DSMMH
Old Dec 5, 2007 | 03:31 PM
DCSpecial's Avatar
DCSpecial
I haven't heard a MBRP with a muffler on a 6.0, only straight piped.
My buddy has the Magnaflow on his 6.0 (turbo back, no cat, with a muffler and a 6" tip)....sounds really good, IMO.
Old Dec 5, 2007 | 04:31 PM
dmalmgre's Avatar
dmalmgre
Magnaflow it is then, thanks guys!
Old Dec 5, 2007 | 04:33 PM
Lonewolftx's Avatar
Lonewolftx
Talking
Wait til you hear the whistle with the window down and you start to step on it . . .
Old Dec 5, 2007 | 04:38 PM
dmalmgre's Avatar
dmalmgre
It's a beautiful sound
pb34
2004 - 2008 F150
17
Jul 11, 2008 10:51 PM
JesseRohr
2004 - 2008 F150
21
Mar 20, 2008 11:24 PM
wiyo120
20
Sep 4, 2007 04:44 PM
BULLDOG-X04
Aug 3, 2007 10:40 AM
