gas tanks
gas tanks
I reciently had a 351w installed in a bronco that I have had for a while. I assumed that the engine builder drained the fuel tank but after about 5 tanks run through it, I am starting to wonder. The fuel filter was clogged up and when water comes out if the tail pipes, it blows **** on the ground. Should I go through the trouble of removing the tank or keep using high grade and some sea foam????
If you have no cats and an exhaust system with flowmaster mufflers or the like, you will always get soot in your exhaust and water blowing out the tailpipes on fire over. The air is cold and the exhaust is hot, and therefore you get condensation in the system that either gets trapped in the bottom of your muffler or blown out the back.
As for the tank... I'd get two of those clear plastic filters with paper elements in them that let you see the gas and put one in front of the tank and one in front of the fuel pump at the engine block. Then let the filters work.
If you are worried about water in the system, use dry gas to take care of that.
Draining the tank can help, but many times its not going to completely solve the problem of debris in the fuel system, because all the debris will not drain out, and what doesn't sits on the bottom of the tank, and many times work its way to the sender the completely clogs the system when you refill the tank.
jjpski
05-07-2014 03:07 PM
Superred2
29
12-04-2010 04:25 PM
