powerstroke problem... need all suggestions
Old Dec 6, 2007 | 07:18 AM
poorbugger's Avatar
poorbugger
No problem, I thought you might have overlooked that.
Old Dec 6, 2007 | 09:44 AM
Neal 97 250's Avatar
Neal 97 250
Yes you can run the engine with the VC's off. If you have only let it idle I would try to drive it and get it good and warm before you send it to the Stealer. It may just be that the GP's haven't been able to get it warm enough to run smooth.
DO NOT TAKE IT TO THE sTEALER AT ALL. We can fix it here. and Welcome to FTE.
Old Dec 6, 2007 | 11:05 AM
poorbugger's Avatar
poorbugger
Thanks Neil, good one, I'm trying to avoid the stealer as much as possible. At the risk of sounding very novice, I get what GP is but what is the VC. Also, I picked up a fuel filter and will change it this afternoon as well.
Oop's wait... got it VC is Valve Covers.
Cheers
Old Dec 6, 2007 | 08:24 PM
poorbugger's Avatar
poorbugger
Unhappy Bad news
Hi again everyone, I've changed the fuel filter and there is no change. Still the same rough idle and absolutely no power, even the revs take a while to get up. It really sounds congessted and clogged up. When I put it in gear, the revs drop significantly and it seems like a put-put. Can get it up a ramp either, absolutely floored. Its been idling for over 24 hours non stop??
Old Dec 6, 2007 | 08:45 PM
youngie22's Avatar
youngie22
Well guys my truck was showing an error code.. I forgot if it was a 4470 or 0470, something close to that. I replace EBP sensor and seems to be back to it's normal self. I really appreciate all the help and suggestions. I changed the oil, replaced serp. belt, replaced block heater; I now hope I am good for another 5 thousand or so miles!
Old Feb 16, 2013 | 08:04 PM
Rodney Sussek's Avatar
Rodney Sussek
Not owner yet. ? Though. Looked @ f350 05 yesterday,all great (pri own) 297k ,all looked and sounded as it should. Left a dep. Came back to pick it up and drove away and accelerator , while under power would just go dead and come back just like that and all the gages are dead for a few and back oh ya radio dead 2 did look for any more. But took back and got money. Really like truck and would likw to know what it would be and how hard of a fix tanks for any info
InOverMyHead
15
Jan 19, 2015 09:11 AM
JR2980
Jun 15, 2014 08:39 PM
acf6
Jan 6, 2013 03:45 PM
Morton4763
Jan 23, 2011 10:30 PM
marcs724
Jan 30, 2008 06:54 PM
