speedometer calibaration...
Old Dec 4, 2007 | 12:06 PM
thunderb's Avatar
thunderb
I have a 3spd manual '79 F100 with 2.75 gears. Currently it reads about 5 mph under when driving, ie running at 60 mph on the speedo gps' at 65mph.
I have taller tires than the stock 205/75R15, using 235/75R15.
I'm regearing the rearend to 3.50 gears and want the speedo to be accurate when finished.
Do I change a gear in the tranny or speedometer?
How do I calculate what gear I need?
Is is hard to change?
Old Dec 4, 2007 | 12:16 PM
Mil1ion's Avatar
Mil1ion
In the transmission.
All speedometers are the calibrated thesame.
You need a driven gear that turns slower.
They are colour coded for ease of recognition.
You can do the check here.
https://www.ford-trucks.com/calculat.../p-tire_sizes/
Old Dec 4, 2007 | 03:03 PM
Mil1ion's Avatar
Mil1ion
P235 R78-15" = L78-15
3 spd MT w/3.50 axle ratio = driven gear C1DD-17271-A
driven gear = Type 2A- 20 teeth - Orange in colour
You should be removing a TAN ( with oil dis-colourment) coloured one
Old Dec 4, 2007 | 04:00 PM
thunderb's Avatar
thunderb
Thanks, I see why you're Da Man.
Old Dec 4, 2007 | 04:33 PM
Mil1ion's Avatar
Mil1ion
THanks !
I'm "Da Man".
Because the guy who suggested it ...wouldn't get away with " Duh Man ! "
He would have been racked over the coals
Old Dec 5, 2007 | 06:39 PM
rusty7983's Avatar
rusty7983
or try to borrow a gps. they have a way of calculating speed by satelite.
Old Dec 5, 2007 | 06:41 PM
rusty7983's Avatar
rusty7983
hey dennis, my door doesn't have a tag and the tag on the rear end is rusted off. my speedo is off. the gear is red now. duh? i need to get my wifes gps working.
Old Dec 5, 2007 | 08:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C1DD-17271-A speedo gear was black, it has been replaced (superceded) by Ford to: C8SZ-17271-B which is orange.
The gears (15 thru 21 teeth) are still available from Ford.
C8SZ-17271-B .. 20T Gear-Orange ~ Ford list price $8.42.
Old Dec 9, 2007 | 12:27 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Ok, maybe not a question with an easy answer, but...
my truck with a C6 and 3.00 rear end and 235/75R15 tires the speedo was dead nuts on. Now with 31" (30.5 actual) tires and 3.50 rear gears the speedo reads way fast. What gear would I possibly move to? I believe the gear is red (it's been a while and it's 10 degrees outside at the moment)
Josh
Old Dec 9, 2007 | 01:16 PM
Mil1ion's Avatar
Mil1ion
30" and a P235 78R 15" are practically the same thing
With P235 75R 15's you are only 3% off the mark.
Old Dec 9, 2007 | 01:38 PM
77f2504by4's Avatar
77f2504by4
notice his rear gear ratio was changed from 3.00 to 3.50...
im having a similar problem, i have 32/12.5 r16 4.11 gears and my speedo is off by about 5 mph to fast, it says im going 65 and i'm only going 60. the current gear was white maybee tan? which once should i try now?
Old Dec 9, 2007 | 02:16 PM
Mil1ion's Avatar
Mil1ion
I'll get back to you.
check the caluculator I posted
Old Dec 9, 2007 | 03:54 PM
Bullitt390's Avatar
Bullitt390
Well 235 series tires are 28.8" and what is the ACTUAL measurement? Maybe 28? My 31" BFG TA/KO tires measure 30.5.
Also the gear change from 3.00 to 3.50. So I think my speedometer reads 5 MPH fast at indicated 40 MPH according to the Police speed signs around town (in other words I actually going 35, but the speedometer says 40).
Josh
Old Dec 9, 2007 | 05:49 PM
Mil1ion's Avatar
Mil1ion
235mm is the tire width
75 % of that is 176.25
divided by 25.4= 7"
7 + 7 + 15 = 29 " Mounted on wheel tire height 30+ " with inflation
Old Dec 9, 2007 | 08:06 PM
Bullitt390's Avatar
Bullitt390
Actual tire height is less than the written sidewall height.
And I already said a 235 tire is 28.8 inches.
Josh
