Fuel Leak.
Old Dec 4, 2007 | 11:48 AM
PAVEMENTMAN's Avatar
PAVEMENTMAN
Fuel Leak.
I Noticed A Small Puddle Of Fuel In The Valley Of My Engine And Was Wondering What It Could Be. I Called A Local Diesel Repair Garage And He Said It Could Be Several Things. O-rings Fuel Pump , Lines, He Said If Its The Fuel Pump It Would Be 350.00 For The Repair Including The Pump. Does Thid Sound High???
Old Dec 4, 2007 | 11:59 AM
61 uni's Avatar
61 uni
He is trying ti rip you a new a$$ hole. I think the pump is around
100 bucks.
Old Dec 4, 2007 | 12:01 PM
PAVEMENTMAN
He Said The Turbo Has To Be Removed To Install It. It Dont Sound Like And Easy Job.
Old Dec 4, 2007 | 01:06 PM
Cuda_jim's Avatar
Cuda_jim
If you have a california truck the turbo needs to come off. 49 states trucks can be done without removing it but it a PITA. $350 doesn't sound too bad, $100 for the pump and 3-4 hours labor @ $60/hour.
Old Dec 4, 2007 | 02:35 PM
THUNDERBOLT5150's Avatar
THUNDERBOLT5150
I had a puddle on mine when i first got it. pulled the fuel filter off and found one of many fuel lines under it that had a small leak on it. replaced all of the hoses and put the filter back on and its all good now. i think this shop is giving you worst case scenario. hopefully yours turns out to be something simple too.
Old Dec 4, 2007 | 04:22 PM
Todd525's Avatar
Todd525
Pump is about 75 bucks for the Bosch at any advanced auto. Where are you located?? I bet you could get someone here fromthe board that isnt to far from you to do it or hel p you with it. It taqkes about an hour to change if you have a knowledge of what is going on. its not hard at all. I think hes trying to rape you. Even our local shop only charges 65 to put one in. I have done three now. NONE of them cali trucks, thank god, and will never do a cali truck either. And no the turbo doesnt have to come off. Thats the idiot way for a shop to charge you a bundle
Old Dec 4, 2007 | 07:19 PM
Hussler's Avatar
Hussler
Did mine last weekend. Took most of the day but did not work at it really hard. Total cost was about $80.00 with banjo washers. If you have the tools you can do it. I've been at this site for about 4 months and have been reading everthing that is posted. Thank you site, this is my first diesel.
I was really surprised how loose all the hoses were from the pump to the fuel filter were. All the clamps I could spin around by hand. Also the banjo bolt was loose .. well it did not require a lot of force to break loose. But it did appear the leak was from the fuel pump so I figured to just go for it anyway. You might want to check that out before purchasing a pump.
The pump was not that hard. The fuel filter was a B&*$ to get out of the way. Also re-installing the banjo bolt with new washers was not the nightmare I thought. My sears wrench 1 1/4 inch worked great without heating and bending .. go figure. Be advised the pump does not come with the banjo washers, at least at Checker .. other auto sites as I had to get them at the International Dealer .. Damn I enjoyed the visit as I think I will only go there for the parts. They were really helpfull.
Would I pay $350 for the job. Yep, if I had the money. My ribs are still sore from this job laying on the front of the truck. Some of you young bucks might be able to do it 1 hour but I'm in my mid 50's I don't thing that is realistic.
97 F250 PSD CC, 150K, 4WD all Stock with custom interior .. wood grain everywere.
Old Dec 31, 2007 | 10:13 AM
PAVEMENTMAN
Well I Let The Guy Install It For Me And He Did A Realy Good Job, No More Leaks And No Sore Ribs.
