Sponsored by: Real Truck
Brake noise?
Old Dec 4, 2007 | 09:40 AM
parkermrk's Avatar
parkermrk
Question Brake noise?
I have a 2002 F250 4x4 that is making noise when I apply the brake. It's not a squeeling noise. It's more like a loud hum. It quits if the brakes are applied real hard. The noise sounds like it's coming from the right front. I have replaced the brake pads, turned the rotors and replaced the caliper on the right front and it is still making the same noise. Any ideas???????
Old Dec 4, 2007 | 09:53 AM
thedaddycat's Avatar
thedaddycat
Did you clean and lubricate the caliper slide pins? I was getting the squeal that went away when the brakes were pushed a little bit harder, found both upper pins on the front rusted up. I am picking up the axle dust seal today(had to replace knuckle seal which dealer had but of course they had to order dust seal...) and will have it back together in a day or so. I hope that will take care of the noise until I replace the brakes.
Old Dec 4, 2007 | 05:49 PM
parkermrk's Avatar
parkermrk
I did lube the pins when I replaced the brakes but I used regular axle grease. Today I bought some synthetic caliper grease and relubed the pins. I hope this fixes the problem.
Old Dec 4, 2007 | 09:15 PM
empiretc's Avatar
empiretc
what kind of pads did you install?
Old Dec 9, 2007 | 05:56 PM
parkermrk's Avatar
parkermrk
I installed the the best brand that 0'reilly carries.
