can it be??
Old Sep 28, 2001 | 01:27 PM
vinster's Avatar
vinster
can it be??
that bad, or different types of gas will trigger my engine light? Every time it gets worse i'm gonna pull this or replace that, then i go and fill up, then the light stays off!! anyone else?
Old Sep 28, 2001 | 03:16 PM
Herman's Avatar
Herman
can it be??
My daughter has an 96 Escort that did what you are discribing. You could check by filling up your gas tank, then when you get home disconnect your battery for at least 10 min. After you plug your battery in the light will go off and stay off until you open your gas cap again (i.e. fill up) The problem is in the purge canister or the solenoid (or sensor) that controls it. The computer thinks there is something wrong. Good luck.
Herman
Old Sep 28, 2001 | 03:35 PM
Herman's Avatar
Herman
can it be??
2004f250superduty
Nov 4, 2013 11:40 AM
abyars111
Nov 12, 2012 09:18 AM
armour01
2004 - 2008 F150
Oct 16, 2012 02:11 AM
blackford97
Sep 5, 2011 10:28 PM
skip hatfield
2004 - 2008 F150
Mar 17, 2010 02:02 AM
