I have an 05 Superduty Crew cab with a factory powered moonroof. Can an overhead DVD monitor be installed? I have the KR edition and am unsure how it would look or if I want to cut the back of the seats. I am looking for opinions on video options also. I do not mind cutting the seays but I am not sure about the angle.
I have installed overheads in vehicles with factory moonroofs before. The only thing you should be careful of is how you will be mounting it. If there is enough space to mount it and use some roof brackets as support you will be perfect, if not, you will just be mounting the unit to only the headliner and it can cause vibration and the headliner to sag.
If you have the $$ I personally would do the headrest TV's. A company called Myron and Davis makes them vehicle specific (I am sure there are more companies like this), so there is no cutting of headrests and when you sell the truck you can remove them, put the stockers back in, and sell them. Depending on where you get them they can be pricey. These allow you to hook up PS2 or things like that to them.
