vacuum hoses
Old Dec 3, 2007 | 07:18 PM
whistlingdeuce's Avatar
whistlingdeuce
vacuum hoses
I was working on my 91 f150 today and slipped and broke the green and yellow plastic vacuum hoses on the drivers side of the engine. they were very very brittle from the heat of the engine and their age. does anyone know where I can get new ones or should a raid a junkyard for some used ones. thanks for any and all info.
Old Dec 3, 2007 | 07:35 PM
MustangGT221's Avatar
MustangGT221
Go to your local auto parts store and use rubber vacuum line to replace it...
Old Dec 3, 2007 | 07:55 PM
Engine's Avatar
Engine
The exact same line broke on my 88 - 300 this weekend. I picked up the smallest vac hose the parts store had in stock but have not tried it to see if it works or not. Hope it does.
Old Dec 3, 2007 | 08:24 PM
kcb37's Avatar
kcb37
You don't have to have the plastic vacum hose so long as both ends are the right size you can use rubber hose and it will work fine.
