truck wont start.electrical problems.
Old Dec 2, 2007 | 02:23 PM
Hillbilly_Deluxe's Avatar
Hillbilly_Deluxe
went to town this moring and shut my truck off for 2 minutes only to find that it wouldn't start. at first it just clicked but the secound time i tried it wouldn't do anything so we boosted it with a buddies truck and it barly started. once it was going the amp guage was all over the place. batery and alternator were both new within the last few months. truck is a 94 f150 302.
any ideas what could be wrong?
Old Dec 2, 2007 | 07:41 PM
flareside_thunder's Avatar
flareside_thunder
How bout the voltage regulator?Also, check to make sure ALL your connections are tight....grounds positives solenoid wiring and so on.Luck
JR
Old Dec 2, 2007 | 09:33 PM
kcb37's Avatar
kcb37
I would agree. Sounds like your battery went dead. You just need to figure out why. Start with loose connections, have the battery and the alternator checked and check your regulator.
Old Dec 2, 2007 | 10:10 PM
89frankenford's Avatar
89frankenford
kinda sounds like a bad regulator or a bad starter. my guess would be a bad starter though. test them both. if you are not getting 12 volts through one of them then thats your problem
Old Dec 2, 2007 | 10:19 PM
Hillbilly_Deluxe
staerter was replaced a year or to ago. it will start pretty good if you boost it. where is the regulator and how do i test it?
thanks
Old Dec 2, 2007 | 11:00 PM
89frankenford
should be on the passenger side fender near the battery. follow the positive battery cable to the regulator. then the positive cable goes from the regulator to the starter.
Old Dec 3, 2007 | 11:42 AM
Hillbilly_Deluxe
okay now i know what your talking about. I charged the battery and cleaned all the connections. the first time i tried to start it nothing happnd so i jumped the posts on the regulator. and now it seems to be working fine.
Old Dec 3, 2007 | 12:24 PM
subford's Avatar
subford
That item is called a Relay not a regulator.
If you have charging problems the regulator is inside (on the back) of the alternator.
Old Dec 3, 2007 | 04:28 PM
flareside_thunder
Whoa now I'm confangled.......The way Travis described it makes me think Solenoid.....and then he said he jumped the posts......so now I'm seein nothin but solenoid......
JR
Old Dec 3, 2007 | 04:52 PM
subford's Avatar
subford
JR
He has a 94 so it would be a Relay and not a solenoid. The solenoid on a 94 is mounted on the starter.
Old Dec 3, 2007 | 05:58 PM
89frankenford
thats what i meant solenoid not regulator. been a rough day/weekend
Old Dec 3, 2007 | 07:54 PM
Hillbilly_Deluxe
well what ever it was its working now. thanks for the help.
Old Dec 3, 2007 | 08:29 PM
kcb37's Avatar
kcb37
I don't know for sure but if you have an external regulator it should be on the firewall. (could be wrong). Internals are part of the alt.
Riverhill85
Mar 2, 2014 08:02 PM
sbjess03
1983 - 2012 Ranger & B-Series
Oct 26, 2010 02:07 PM
Motorsportsartist
Aug 6, 2010 03:18 PM
bluebird
Jun 27, 2006 06:12 PM
